Can you check the ign. module?
Subscribe
Jan 2, 2001 | 03:18 AM
Is there any way to check/measure if the ignition module in distributor is b
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Reply 0
Jan 2, 2001 | 09:42 AM
As far as I know there isn't a way to check it with a volt/ohm meter. And It doesn't even put out any codes if it is bad!
But if you car runs worse as it heats up it is a pretty good chance it is the module going bad.
They are pretty cheap, $24, and if your car has over 50,000 miles on it, it would be a wise thing to replace.
89 IROC 350 Auto
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
14.01 @ 97.0mph with 2.77's gears and a bad ignition control module!
And Free mods.
Reply 0
Jan 2, 2001 | 05:55 PM
You can take the module to a local auto parts store and they should be able to test it. The Auto zone in my area tests modules for free.
Reply 0
Subscribe
