Suggestions for L98 buildup???
Old Dec 31, 2000 | 11:00 AM
IrocManiac's Avatar
I am looking for suggestions on intake/runners, heads, cam before I start orfering for the L98 rebuild. I am going to have at 3500 or so to spend on the motor because it will cost me another 1000 to have someone drop it in. I was thinking edelbrock intake, and as&m runners if I can afford them. Does anyone have a link to their site because I haven't been able to find AS&M at all. What heads??? A custom cam and some SLP headers. Any suggestions would be great. Thanks guys.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Dec 31, 2000 | 04:29 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
$1000 to install a motor? Keep looking, man.
Does the $3500 include building the shortblock or just mods?
SLP 1-3/4" headers - $400
SFCs- $200 installed (average)
Edelbrock intake (carparts.com or carpartsonsale.com) - $350 shipped
as&m runners - $400????
ported plenum - FREE
holley afpr - $75 (or so)
good cam - $250
bore your stock tb to 52mm - $150
scat 383 crank, balancer, & balancing - approx. $750 (just a guess)
unless you have $3500 just to spend on mods I'd recommend a set of sportsman II heads - $700 complete
comp 1.5 roller tip rockers - $150 (if you shop around)
or
full race rollers - $300 (waste of money IMO)
Hooker or Flowmaster 3" catback - $250 (or so)
Gutted cat - FREE
TPI airfoil - $30
95 4.3 s-10 converter - $100 rebuilt (2300-2500 stall)
GM truck motor mount for driver's side (to help the slp headers clear) - $35???
chip - sky's the limit or learn to do it yourself
that's all off the top of my head
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Old Dec 31, 2000 | 11:10 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
Here is the link to AS&M. www.azspeed-marine.com
Old Jan 1, 2001 | 01:15 AM
IrocManiac's Avatar
I have to buy the block with that money. I have a total of 4500 to spend including the install and exhaust stuff but I already have 3" flows on it. I just need some advice on cam and intakes. I am leaning toward edelbrock just wanting some info because that is a lot of money for a college guy to drop on his ride.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
Old Jan 1, 2001 | 07:15 AM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Hey, you are also in COFBA arent you??
We should meet up sometime I live right by Warr Acres.
First of all,
The Edelbrock,Accel and TPIS Bases are almost identical. In the runners you could have the AS&M or the SLP siamiesed runners.
The cam is most important part.
I would call the cam company, tell them what you want out of it (IE. Gas mileage,High performance Streetablity,ETC...)
and tell them some stats about your heads. and what you want to do NA, NOS, Blower.
and where do you want your power range to be.
91 Z28 5.7l Camaro
T-56, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Jan 1, 2001 | 10:46 AM
IrocManiac's Avatar
I do live in warr acres and feel free to e mail. I work at best buy and my name is Trey you can come by and check all the cool electronic stuff I hang out on 39th occassionaly. drop me an e mail, any more Engine suggestions guys would be great.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
Old Jan 2, 2001 | 01:10 AM
IrocStan's Avatar
If you are planning on using a late model 1 piece rear main engine block, DO NOT WASTE YOUR MONEY ON A 87-89!! THEY ARE PRONE TO CRACKING IN THE LIFTER VALLEY! I pulled a cracked 305 out of my 87. I was told 87-89 chevy V-8s are very likely to crack, so like an idiot I bought a complete 350 out of an 88. I put in new bearings, rings, timing chain, oil pump etc before installing it. Friday, I pulled off the intake to do a cam/intake upgrade and guess what I found... Agghhhhhhhhh!!
But this does give the perfect opportunity for a 383
87 IROC 350, 3:42 Torsen, pocket ported 083 heads, complete Edelbrock exhaust, Most free mods, Most little mods, aluminum d/s. Edelbrock STB, SSM sfc's, boxed rear suspension pieces, urethane bushings everywhere.
Stock cam, chip, runners, base, and trans
13.94@103mph, 2.25 60'
In the works: ported SLP runners, ported base, Xtreme Cam, homemade suspension pieces, and 27x10 Hoosiers.
Goal: 12.999
Old Jan 2, 2001 | 11:31 AM
blak92!'s Avatar
I thought only the 305s were prone to crack in that area, not the 350s. Who knows, it is probably speculation?
'92 Z28 Black 5.7L 5 Speed
'95 Competition Yellow Corvette Coupe 6 Speed
Old Jan 2, 2001 | 09:12 PM
Earl 87gta's Avatar
When I built my engine I used a 350 tuck engine out of a 96 gmc truck it was a core motor from the salvage yard cost my 150 I had the crank turned and the block bord 30 and every thing balancd 500 sumiit fluidampr 200 tci converter 265 bought an engine rebuild kit from SDPC 350
gm hot cam kit around 500 kit had cam roller rokers springs and retaners. gm PM rods used in lt4 150 then 40 to have pistons preced on.
My heads are l98vett heads 500 salvage yard 3angle valve job 100 and ported and polished them my salf using the standerd abrasivs kit I then ported the plenum and base my self and bought a set of slp runners 200 jet afpr 80 air slp air foil 30 and a set of slp headers with install kit came out around 500 and I got a used borola cat back for 300.Its bprobly not the fastst thing on the road but it is a good all around car.
FormulasOnly
Jul 23, 2018 08:47 AM
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
