egr plugs??
Old Jul 28, 2007 | 10:23 AM
ironleg's Avatar
Car: 1988 iroc z28
Engine: 357ci
Transmission: 4sp auto
Axle/Gears: stock for now
egr plugs??
i know its hear some place but i cant find it i removed the egr valve off the motor what can i do with the holes in the plenton and or the intake runners the intake is still on the motor and i dont want to take if off if i dont have to and the plentom and runners are off the motor
Old Jul 28, 2007 | 11:29 AM
LVZ2881's Avatar
Car: 1988 IROC
Transmission: 5 speed
Axle/Gears: 3.08 Posi 10 Bolt w/ aluminum drums
Re: egr plugs??
I had a friend who runs late model stockers build me a block off plate for lower intake....thats really all you need.
from my understanding, when you remove the egr, you need to reprogram the pc as there is supposed to be something in the ecm thats plays with the timing when you have egr.
Old Jul 29, 2007 | 09:34 AM
ironleg's Avatar
Car: 1988 iroc z28
Engine: 357ci
Re: egr plugs??
with the mods in the car i know i will have to change the chip thanks for the input but what about the openings in the plentum should i do anything with them????? thanks
Old Jul 29, 2007 | 02:51 PM
DZcode's Avatar
Car: 1969 Z28
Engine: 406 TPI
Transmission: Tremec TKO 600
Axle/Gears: 3.31
Re: egr plugs??
On the intake manifold, remove the EGR valve and put in a block off plate like LVZ2881 suggests.
Put a cap on the one air nipple on the plenum for the EGR valve vacuum hose.
There shouldn't be any other openings on the plenum for the EGR valve. There are other nipples for the FPR hose, MAP sensor, PCV, etc.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
rjcme
Sep 5, 2015 01:23 PM
