For those with the LT4 HOT Cam and the World Products SB-Chevy Sportsman-II Heads....
Old Jan 6, 2001 | 05:58 PM
CamaroX84's Avatar
I am looking into getting the LT4 HOT Cam and the World Products SB-Chevy Sportsman-II Heads for my 89 350 TPI motor. My questions are:
Is the idle real lopey, or is it actually normal?
Do I need different springs/retainers than what the assembled heads come with?
Do I need new rockers? If so,
recommendations?
What kind of power are you guys getting out of this?
Any help would be much appreciated. Thanks.
Old Jan 6, 2001 | 07:50 PM
Tom Keliher's Avatar
1) It has a definite lope at idle: http://www.geocities.com/motorcity/g...031/idling.mpg
2) The springs that come on the heads, if you order them as built by World, are OK to use as is. Be careful about other suppliers who buy bare heads and then assemble them with their own components. The World springs are good for .560" lift.
3)The cam is designed for 1.6 ratio rockers, which is what I use. I suppose you could use the 1.5 but you won't realize maximum performance.
4) Enough
I recommend you upgrade your induction system as well.
FORMULA 350 TK
Southern California 3rd Generation F-Body OrganizationŠ
Old Jan 6, 2001 | 08:33 PM
Jason Aschle's Avatar
I agree with all of what Tom said. I had my engine built from scratch and have no regrets whatsoever. You will definately need to upgrade the intake for more airflow.
http://sc3gfb.org/members/jason.html
1991 Camaro ,polished TPI, 355ci. Sportsman 11 heads, LT-4 Hot cam,Pete Jackson gear drive, on,and on, and on... 13.6 @ 102.5 with a 2:73 open rear, no traction, no tuning, no practice. Car is pictured in Chevy High Performance magazine, June 2000 issue.
1985 California Edition IROC red, polished TPI and polished wheels, otherwise completely stock 305ci. 700r4
1991 fullsize Blazer 4-wheel drive, 350,700r4, Pro Comp lift, K&N, TBI spacer, 3" Catco cat, 3" cat back Flowmaster, etc....
theurge
Aug 21, 2015 12:46 PM
80s Poncho
Aug 19, 2015 06:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
