need help with timing?????????????
Old Jan 6, 2001 | 10:27 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
I got a timeing light for Christmas. I have never timed a car before. I dont know what my timing is supposed to be set at stock. I have looked in my Helms and Haynes manuels and they both said to look in my owners manuel or under the hood on the emissions sticker. I have neither. It is an 87 Iroc-Z l98. If you can help me out that would be cool. Thanks
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
Large tube runners
ported plenum
Holley afpr
SLP 1 3/4" headders (not installed yet)
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false
Old Jan 6, 2001 | 10:54 PM
theformula's Avatar
6*BTDC (before top dead center)
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom K&N cold air intake, SLP airfoil, ported & hi-polished plenum, March pulleys, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers,10*BTDC,MSD coil,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Street legal with stock throttle body, runners,intake manifold,cam, and heads.
Old Jan 7, 2001 | 03:00 AM
86IROC305's Avatar
You will also need to disconnect the tan/black stripe wire above the blower motor, otherwise the computer will advance the timing and you won't get a true reading....
86 TPI 305 Iroc-Z
700R4 (rebuilt)
3.42 Posi
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams High Energy H268 218@.050 454/454
Old Jan 8, 2001 | 01:27 PM
Ski89Z28's Avatar
You do know how to connect the timing light?
And you do know where the #1 cylinder is too?
Right?
It may sound stupid but I didn't know where the #1 cylinder was when I started timing my car and boy was that a mess!LOL.
Depending on mods I heard people advancing the base timing up to 12*. But it is good to go to the track when fine tuning.
Good Luck and have fun!
89 IROC 350 Auto
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
14.01 @ 97.0mph with 2.77's gears and a bad ignition control module!
And Free mods.
Old Jan 8, 2001 | 01:34 PM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
6* is stock for a little more ***** try 9*-10* especially if you don't have an aftermarket chip which would advance your timing itself
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
