thinkin about using a msd-6al box
Old Aug 3, 2007 | 07:28 PM
firebirdowner89's Avatar
Car: 89firebird
Engine: 355 TPI
Transmission: world class T-5
Axle/Gears: 3.73 posi
I have a pretty mildly built 355 tpi with 10.3 to 1 comp. ratio and crane powermax roller cam, roller rocker arms ported and polished vortec heads port matched tuned port, custom prom well im thinkin of using a msd 6al box to help out the stock ignition its an just woundering if this would help out on my 89 firebird it has the small cap HEI with the electronic advance .....would this help my ignition any? thanks
Old Aug 3, 2007 | 09:51 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: thinkin about using a msd-6al box
I've heard from at least two sources that for our cars, they're not a real improvement. Not exactly what I wanted to hear (since I have one), but there ya go. Apparently the ignitions on our cars are fairly decent, so unless you're running boost or N2O (which increase cylinder pressure, which can "blow out" a normal spark), there's just not a hell of a lot to be gained by adding one.
(This of course assumes that your stock ignition is working as designed!)
I'd guess that you might see better gains with a different mod, one that addresses whatever your current "bottleneck" may be...
Good luck.
Old Aug 5, 2007 | 02:35 PM
Rick Routzahn's Avatar
I have run the MSD and ACCEL both in the past and my car seemed to run a little smoother and gas mileage increases a little.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
