for those with zz4 cam
Old Jan 12, 2001 | 09:25 AM
travsirocz's Avatar
Car: Two 1987 Iroc-Z Z28s
Engine: 5.7 TPI ZZ4 1.6 Roller Alum. Head
I was wondering some of your thought on this cam. I plan on using the zz4 cam 1.6 roller rockers and edelbrock performer rpm heads with the stock tpi set up. What times and hp figures are you getting. thanks for any info.
1987 Camaro Iroc-Z Z-28 with a TPI 5.7
-Ram Air,K&N Filterchargers, Gutted Mass
Airflow Sensor, Throttle Body Airfoil,
Edelbrock TES Headers and Y pipe, Gutted
Cat, 3 inch exhaust, Flowmaster
-Hypertech Thermomaster Chip, 160 deg Stat,
Adjustable Fuel Pressure Regulator
set at 50 psi, MSD Cap, MSD 8.5mm wires,
Accel Coil, MSD 6AL Ignition Box, Accel
Plugs
-Richmond 3.73 Gears, B&M Transpak,
B&M Rachet Shifter, Energy Suspension
Products
-Fiberglass Cowl Induction Hood,
Purple Neon License Plate Frame,
16X8 Rims with BFG 245 50's,
Pioneer Deck, 2 JL 12's in a Q-Logic
Box with a 300 Watt amp
What you can put between your ears,
no one can take away.
Old Jan 12, 2001 | 02:26 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I used the ZZ4 cam with my L98 aluminum heads, SLP 1 5/8" headers, and ported stock intake. It made 285 HP at the rear wheels. I think its a great cam for a mild to moderate 305 or 350 TPI. Check the other mods in my sig. Dont forget you need new valve springs, as the stock ones wont handle the lift. Scoggin Dickey has this cam on sale right now for $100. www.sdpc2000.com
EDIT: I dont think you'll need new valve springs with the Edelbrock heads, but double check with them to make sure. With 1.6 rockers the exhaust lift is about .540".
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
[This message has been edited by Kevin91Z (edited January 12, 2001).]
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Magman
Sep 13, 2015 12:14 AM
masonta
Sep 1, 2015 06:40 PM
