anyone here using edelbrocks rpm heads???
Old Jan 10, 2001 | 08:40 AM
travsirocz's Avatar
Car: Two 1987 Iroc-Z Z28s
Engine: 5.7 TPI ZZ4 1.6 Roller Alum. Head
If so do you like them. What set up are you using. What cam and lifters. What all do you like and dislike about them. Let me know thanks! trav
1987 Camaro Iroc-Z Z-28 with a TPI 5.7
-Ram Air,K&N Filterchargers, Gutted Mass
Airflow Sensor, Throttle Body Airfoil,
Edelbrock TES Headers and Y pipe, Gutted
Cat, 3 inch exhaust, Flowmaster
-Hypertech Thermomaster Chip, 160 deg Stat,
Adjustable Fuel Pressure Regulator
set at 50 psi, MSD Cap, MSD 8.5mm wires,
Accel Coil, MSD 6AL Ignition Box, Accel
Plugs
-Richmond 3.73 Gears, B&M Transpak,
B&M Rachet Shifter, Energy Suspension
Products
-Fiberglass Cowl Induction Hood,
Purple Neon License Plate Frame,
16X8 Rims with BFG 245 50's,
Pioneer Deck, 2 JL 12's in a Q-Logic
Box with a 300 Watt amp
What you can put between your ears,
no one can take away.
Old Jan 11, 2001 | 01:40 AM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I have the #6089 performer RPM heads (64cc). I quite like them. 170cc intake are small enough and yet big enough. It depends on your ultimate goal.
I run these heads with a ZZ3 cam with 1.6 rockers on the intake. I run a 1986 TPI setup, with ported upper and lower intakes, 52mm TB, airfoil, stock runners with blended entrance and exit, afpr, etc. etc.
I am very pleased with the combination. The quality of the heads was impressive as well.
Mark.
Old Jan 12, 2001 | 09:22 AM
travsirocz's Avatar
thanks
Old Jan 13, 2001 | 10:37 AM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
All of the information is in the sig. Personally I really like this combo. It runs great, and pulls hard. I'm running *about* a 13.3 with this setup, but I haven't taken it to the track yet.
Black 88 GTA L98
New engine is in!
ZZ4 bottom end, Edelbrock 6085 heads, LT4 HOT cam, GMPP 1.6 RR's, ported stock TPI, SLP 1 3/4" headers, no cat, Dynomax cat-back
E.T.F.A Member #11
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Sep 17, 2020 08:26 AM
beastin91rs
Oct 9, 2015 07:38 AM
Reddeath210
Oct 6, 2015 08:20 AM
TreDeClaw
Aug 14, 2015 06:58 PM
