What is causing my car to run so rich??
Old Jan 10, 2001 | 12:31 AM
nelliesIroc's Avatar
I have an 87 camaro with a 305 tpi. It starts right away in the morning but later in the day if I try to start it I have to give it gas inorder to get it to start. It idles realy really rough plus I can smell gas lik its running rich. When on the freeway sometimes it will throw a code 34 and a 45. I know the 45 is the O2 sensor. Could the O2 sensor or the maf cause these problems or is it something else?
Old Jan 10, 2001 | 04:47 PM
irocbsa's Avatar
Check and/or replace the O2 sensor, MAF sensor, MAF sensor relay (located on the firewall on the drivers side) and also check and/or replace the Coolant Temperature Sensor. The CTS can cause a condition with the symptoms you stated. I had a similiar problem and it ended up being the CTS and the O2 but it would only throw a code for the O2, and this would only happen occasionally. Hope this helps.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat, Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jan 10, 2001 | 05:30 PM
Scott S's Avatar
Just a note about the TFS Twisted Wedge Heads for irocbsa. Those heads were recalled some time ago. If you are experiencing any problems with them you should call TFS and get them replaced. Although they no longer honor the original recall they will replace them for the cost to make them (around 600 bucks). This only applies to the Twisted Wedge Heads for the SBC.
Old Jan 10, 2001 | 10:31 PM
Thanks for the help that reminds me that when I first got my car it threw a code for the CTS. Where is that located and how can I check it?
Old Jan 13, 2001 | 10:34 AM
irocbsa's Avatar
The recall was based on bad valve springs. One of mine broke awhile back. I contacted them and they sent me new ones with the updated design.
bsa
Old Jan 13, 2001 | 10:51 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The CTS is on the front of the engine on the intake manifold on TPI cars. It is relatively simple to get at, just remove your ducting for the air intake and possibly your belt if you have a serpentine. Can't miss it.
To test it, (assuming you don't have a scan tool), measure the resistance. The resistance decreases as the temperature rises IIRC. No resistance is a high temperature reading, unlimited resistance is a low temperature reading. -40C or +151C will through a code. Also a short or open circuit will cause the same effect. 4.7K ohms = 55*F.
Old Jan 13, 2001 | 11:11 AM
Car: Death Mobile
Engine: 666 c.i.
Actually a bad CTS will cause your car to run rich also. The CTS tells the ecm what temperature the engine is. When it is not upto "operating temperature", the ecm will start adding fuel believing that the engine is cold. That is one of the problems with using a 160* T-stat without using an eprom adjusted for the cooler temperature; the ecm adds extra fuel because it thinks the engine is still cold.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
squiggy2
Aug 9, 2015 09:30 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
