383 TPI Computer intake questions
Car: 87 IROC
Engine: GM 350 soon to be supercharged
Transmission: tko 600
Axle/Gears: 3:73
will i have a problem running TPI on this motor its going to be speed density i havnt decided on an intake yet accel super ram or mini ram or the ram jet which one is best perfromance wise?.....its going to have a 92 350 computer should i chip it ? or have it sent out to be reprogrammed ?
I have 383 I just Purchased here are the specs
GM Vortec cast iron heads
Hardened retainers and 1.25'' diameter valve springs
2.02'' swirl polished intake valves
1.60'' swirl polished exhaust valves
Hardened pushrods
Camshaft Specs:
Hydraulic Flat Tappet
Duration @ .050'' Lift: 234 Intake / 244 Exhaust
Lift: .487'' Intake / .508'' Exhaust
Lobe Separation: 112°
Hardened pushrods
Camshaft Specs:
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 383 TPI Computer intake questions
Absolutely you're going to need a custom chip to make a camshaft that large work with a TPI computer. Any one of those three are good intakes.
Ask around amongst your fellow car guys, there has to be someone in New York who does custom chips.
Car: 87 IROC
Axle/Gears: 3:73
prom or a whole computer ? like hypertech sells one and jet perfromacne sells one or should i find someone who burns em?
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
dont waste your time with a hypertech or jet chip or anything equivenent to that.
you will need to have someone custom tune the car if you ever want results
The PROM. And as LoneStar and I said, you need to find someone local to you who does custom chips. The Hypertech and JET are for stock engines, and they dont even do that very well.
Sanjay
Aug 12, 2015 03:41 PM
