Identify this Wire?
Old Aug 6, 2007 | 10:44 PM
Dave Schotz's Avatar
Identify this Wire?
Hey guys... My friend's car has this wire disconnected... and was hoping someone here could Identify where / what it should go to?
Thanks.. I've attached pics from both sides (one engine comp, on Pass compartment... and then a close up wire/grommet)
Thanks for your input.
Dave
Attached Thumbnails Identify this Wire?-iroc-wire-1.jpg   Identify this Wire?-iroc-wire-2.jpg   Identify this Wire?-iroc-wire-3.jpg
Old Aug 7, 2007 | 12:06 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Identify this Wire?
This is a total guess, but since its a manual trans car, that could be part of the clutch safety switch to the starter. The starter will not engage unless the clutch is depressed.
Old Aug 7, 2007 | 08:12 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
year would help. Also the wire connector ends.
I doubt it's related to the clutch safety. That black connector with the yellow and purple wire is the safety switch.
Old Aug 7, 2007 | 10:18 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
That is not a factory wire, someone must have added it for something.
Old Aug 7, 2007 | 01:06 PM
So, no one here has a wire that goes through the firewall below the steering shaft? Thanks, Dave
Old Aug 7, 2007 | 08:19 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
That hole on my car is were the cruise conrtrol harness went through.
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Redwhisper
Aug 26, 2015 05:02 PM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
