lt1 cam do i need a tune?
Old Aug 7, 2007 | 08:39 PM
blackdemon89ta's Avatar
i wanna put an lt1 cam in my 305. it's the maf system so do i need to get it tuned? would a jet chip work? etc..
Old Aug 8, 2007 | 12:10 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: lt1 cam do i need a tune?
No, you should be fine with the stock chip. The LT1 cam is very similar to the TPI cam, only with more lift.
Stay away from off the shelf Hypertech and JET chips and the like. They only do one thing right, and that's take the money from your wallet and put it in theirs.
Old Aug 8, 2007 | 03:13 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I think you would probably benefit from an adjustable fuel pressure regulator the most at this point. Give it a bit more pressure and you should be golden.
Old Aug 9, 2007 | 04:35 PM
cool deal thanks. thats is comfort to hear.
midge54
Dec 27, 2019 04:14 PM
midge54
Aug 29, 2015 09:51 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
355tpipickup
Aug 13, 2015 07:35 AM
