Fuel issue - L98 TPI
Old Aug 9, 2007 | 12:07 PM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
Passing Etest is #2 now, maybe this problem is even relating to it failing
Vehicle runs awesome, until it idles for a long peiord (heating it up for an etest lol) and the fuel pump starts to whine louder, louder then it stumbles and stalls. Fires back up, run rough, give it gas, it studders and stalls. Let it sit 10-15, fires up, runs good. It did it before my etest, let it sit, went on etest, went to car show, drove home, then i thought id try it as I did fuel filter before etest and it was NASTY to maybe it was staining the pump. Well did it again and for 30min no matter how long she sat, no difference. So tonight ill see if it fires up or same issues, either way though I need to fix it.
It is a brand new tank on car and apprently a Holley Hi-flow pump. Could a bad ground or relay produce this problem? If I do need a pump, Im cutting a hole behind the rear seat to pull it out and avoid all the suspension stuff to drop.
Any input would be awesome. Thanks guys.
on a side not, would an Ill fitting gas cap (pressure leaking out) increase HydroCarbons?
Old Aug 12, 2007 | 03:17 PM
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Re: Fuel issue - L98 TPI
(First off, inside gas tank is BRAND NEW everything clean and spotless)
2ndly Id rather have my hole in the back, any problems in future I will have access to it, and everything will be easy to unhook and pull out
Did a pressure test today :
Cold start and run :
50 PSI at idle, spikes to 57-60 on rev
50Psi Idle, 60ish when rev
Then pump heats up, and you can hear it whining :
Dad Hears pump getting louder
Hard to hear on camera, but its MUCH louder then when its cooled off
RIGHT after this, the gauge plumits to 30, then lower, then when u but demand ont he pump by reving, it just falls to 0
PSI drop
Try and restart right after wont prime, pump wont activate :
No Pump power
Wait longer, and SLOWLY hits 50 then drops right off (Sounds strained):
2nd cool down reprime
If I let it cool right off, she'll run ***** out again, until pump gets warm
So new pump and Strainer ordered for tomorrow at 11am. - Total price including PRessure tester - $180.00
Old Aug 12, 2007 | 03:36 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Sounds like a bad fuel pressure regulator. You shouldnt be at 50psi at idle. The pressure regulator is vacuum actuated, so at idle the pressure is lower, then at WOT it should go up to around 47psi. Your pressure is way too high. This would cause the motor to be rich and would strain the pump.
Old Aug 12, 2007 | 03:55 PM
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
So this could be why Im failing etest with Hydrocarbons and my pumps overheating/
Anyone else say its the regulator?
Old Aug 12, 2007 | 04:13 PM
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
it is a holley pump if that makes any diff
Old Aug 12, 2007 | 07:34 PM
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Called pervious owner
Car has a AFPR
So I checked, sure enough lil nut on the top
So me and my dad adjusted it to 35psi at idle, peaks to 44-45 when u rev it, idles smooth, smells clean behind it, also the vac. line to the FPR was split, so i fixxed that.
Runs alot longer then pump whines and dies, my guess is the FPR killed the pump, so new pump is on order, FP is set, car smells so clean, thats where my HC's were coming from!!
So Pump will go in tomorrow or tues, then check timing and stuff and slap her onto the etest again!!
Thanks for all the help guys
Old Aug 13, 2007 | 09:08 PM
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Shes fixxed! Runs awesome (needs IAC) but other then that, ran for 3.5hrs tonight, no hiccups.. Ill take it to work rest of the week and then etest saturday
Old Aug 14, 2007 | 07:05 AM
MattODoom's Avatar
Car: '88 G T/A
I accept paypal or money order.
Old Aug 14, 2007 | 07:25 AM
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Lol Im broke after fixxing it! haha
Thanks though guys!!
Drove the car with my temp. pass to work today, runs great and wow, those TPI 350's and low end grunt eh? Geez
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
beachrodder
Aug 25, 2015 08:05 AM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
