does removing the throttle valve make more power
Old Jan 8, 2001 | 05:26 PM
85F-body's Avatar
i was looking at my throttle body the other day and was thinking that maybe if i take off the throttle valvls (the little flaps that raise up when you push the throttle ) that it will give me more hp or air flow or more overall power
Old Jan 8, 2001 | 05:29 PM
theformula's Avatar
That would screw up the TPI system. Those raise as you know when the accelerator is depressed. Your air/fuel ratio will be screwed.
91 Formula
305 TPI 5speed
1LE/G92/WS6
K&N, SLP airfoil, ported/polished plenum, March pulleys, TB coolant bypass,Crane AFPR(47psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires,Bosch O2sensor, SLP headers & catback,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Street legal with stock throttle body, runners,intake manifold,cam, and heads.
Old Jan 8, 2001 | 05:39 PM
RP1987GTA's Avatar
yes you can remove then ...GM put those little frisbees there in case yer at the beach and lose yers...........
87GTA,350,Auto,MAF screens removed,195 thermostat,cold start injector UNPLUGED,K&N,modified air intake,ADSchip,3:70s,3inch cat back Flowmaster single outlet,TPS.54,Bosch Plat plugs,base timing 6BTDC,22 MPG,what a ROACH,Bilstiens in the rear....,don't let yer meat loaf
Old Jan 8, 2001 | 10:21 PM
85F-body's Avatar
thanks
Old Jan 9, 2001 | 12:57 PM
Kyle F's Avatar
What the hell is this? I have never seen these before. Can you explain further? Does the BBKs have them to?
Old Jan 9, 2001 | 02:51 PM
Humvee's Avatar
Uh... wouldn't your car be basically running full throttle without the proper amount of fuel if it's open? Sensors would sense it's down and supply the fuel accordingly. But there is no throttle plate, it'll be running very lean wouldn't it? Correct me if I'm wrong.
1989 IROC-Z Convertible
305 TPI automatic
White with black top
Mods:
None to date... Working on it!!!
My webpage: http://mindspring.com/~humvee
Old Jan 9, 2001 | 11:01 PM
Kyle F's Avatar
Oh so your just talking about the Throttle Blades. No you cant remove them. That is what controlls the speed of your car. YOu would never be able to stop if you remoived those, or you car would just burn itself up from being way toooooooooooo lean.
Old Jan 9, 2001 | 11:25 PM
85F-body's Avatar
hahahh that would suck
Old Jan 14, 2001 | 09:25 PM
Jason M 91Z's Avatar
Wow.
-Jason M. 1991 Camaro Z28
"Shampoo is better, I go on first and clean the hair."
Old Jan 14, 2001 | 09:52 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
What about making a monoblade throttlebody. Would that work?
Chris
Old Jan 14, 2001 | 10:26 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Someone aready sells one, TPIS, I beleave.
87 Z28 305 TPI, Auto, 2.73, Gutted air boxes, K & N fillters, SLP Airfoil, Dyno Max 3" cat back, Accel 8.8 mm spirals, Accel cap and rotor, Accel coil, rapid fires, and 170* Stat.
Best 15.414 @ 87.47.
Old Jan 17, 2001 | 06:22 AM
Blockhead's Avatar
Hey Cletus just take da gawl darn trottle body off of it! Eberybody knows yous gots to put TBI on it ta make it move!
Old Jan 17, 2001 | 06:45 AM
Kyle F's Avatar
Even TBI has Throttle blades j/k
Old Jan 17, 2001 | 01:09 PM
Blockhead's Avatar
New homemade mod:
My business partner Jack92Formula will be along this evening to describe the process and its uses.
Old Jan 17, 2001 | 01:22 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Street&performance sales a mono blade throttlebody. It flows 1000 cfm, it looks like they took a stock tb and bored it out to an oval.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Jan 17, 2001 | 02:25 PM
Bill91Z
Guest
Posts: n/a
I know Jack personally and they put out a fabulous product. Could really feel a difference once their throttle blades were installed on my 91. What is great about this mod is that you do not have to buy one like I did, you can do this in your own garage with simple hand tools.
Old Jan 17, 2001 | 02:26 PM
87Z-ya's Avatar
That would be cool to remove the throttle blades, just think of the air restriction you will get rid of. Hey 85 fbod, why dont you just take off one of the throttle blades and take it for a drive. Then tell us how great it ran. Man I heard of moron before but????
Old Jan 17, 2001 | 03:22 PM
85F-body's Avatar
hey **** you *** hole
True Power's Avatar
Venturii throttle blade? Perhaps you could describe it a bit? Are those holes in them? If so, I wouldn't put that on a blown engine. Wouldn't that just keep feeding the engine boost, even in idle?
Old Jan 17, 2001 | 03:30 PM
theformula's Avatar
lol 87zya
Old Jan 17, 2001 | 06:20 PM
ede's Avatar
ede
edit message
[This message has been edited by ede (edited January 20, 2001).]
Old Jan 19, 2001 | 04:14 PM
DSouthern's Avatar
Blockhead,
I still have not seen Jack92Formula's details on this modification.
Are these just holes drilled into the throttle body plates or are these replacement plates?
Old Jan 19, 2001 | 04:27 PM
ede's Avatar
ede
you get a template and drill bits. the size and number of holes depends on your intended application.
ICON Motorsports
1st & 3rd
Old Jan 19, 2001 | 05:41 PM
355 IROC-Z's Avatar
LMAO here. sorry but i found that pretty hilarious. obviously you are uneducated on basic fuel injection and/or basic fuel delivery. just alittle friendly suggestion, if i were you i would search the net alittle or get a good book (such as TPIS's book).
yeah, i would still like to see the reasoning and process behind the venturri throttle plates. i'm not seeing how at WOT how strategically placed holes in the TP would have any benefit. i sure hope im not walking into a trap here
Old Jan 19, 2001 | 05:43 PM
DSouthern's Avatar
Ede,
Thanks for the reply.
Did you notice a difference in idle quality? Don't these holes allow additional intake air that is not controlled by the IAC motor?
Old Jan 19, 2001 | 09:04 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Tough crowd. You guys can get mean.
Old Jan 20, 2001 | 12:50 AM
85F-body's Avatar
Edited because I use foul language.
[This message has been edited by Kevin G (edited January 20, 2001).]
Old Jan 20, 2001 | 01:16 AM
Car: Death Mobile
Engine: 666 c.i.
No need to swear 85. While people may forget that we all had to learn somewhere one time or another. And what we might think is a reasonable question others may think is silly, we have to remember that this is a public forum.
I agree with the saying that the only stupid question is the one that is never asked. What no one explained is that the blades on a TB is NOT as important as carb. The TPS has a lot more to do with controlling the ecm (it is kind of like throttle by wire).
The blades are more to help control the vacuum on a MPFI. If you removed the blades, your engine would not go necessarily go WOT...as it still would require the TPS. But you would loose vacuum which could cause some "interesting" problems with MPFI. I can only guess how the ecm would interpet the lack of vacuum on the VE tables.
But please keep it clean. Ok?
Old Jan 20, 2001 | 01:18 AM
Car: Death Mobile
Engine: 666 c.i.
PS: If I had to guess, lack of vacuum on the VE tables would probably make the engine "run away"; if it wasn't under load.
Old Jan 20, 2001 | 02:08 AM
Ski89Z28's Avatar
Well said Glenn!
We ALL had to learn from nothing, since NONE of us was born with this knowledge.
85F-body, Sometimes we are all too anxious to jump the band wagon and kid/joke about someone asking a question but sometime someone post a thread about what was the most stupid thing you ever did while working on your car. And let me tell you we've all done something stupid like touching the coil/spark plug wires and getting shocked and you can't let go to fast and your hand bangs into the HOT headers a few times. Or the guy who finding TDC by manually cranking the engine with a long ratchet on the crackshaft pully then when he was done he forgot about the ratchet and started up the car with it on. Or replacing the T-stat and forgeting to tighten the clamps on the hoses and start it up and when the T-stat opens up and lets the water thru the hose pops off not to mention your in front of the car having HOT water spraying at you and your doing the chinses water drill to get in the car and turn it off.
All in all we're not perfect, atleast not this dumb Pollock!
Keep reading and keep posting cause we're all still learning.
Old Jan 20, 2001 | 09:06 AM
Kevin G's Avatar
Your car will not idle with the throttle blades removed. It will stall out for sure. At idle, the throttle blades are shut, and the idle air control valve (IAC) controls the idle speed, by metering air through a bypass, that goes around the throttle blades. If you took off the throttle blades, it would die out instantly . If you took out the throttle blades, and had the TPS set for wide open throttle(WOT) , it would run full nuts until it broke something
Old Jan 20, 2001 | 11:34 AM
355 IROC-Z's Avatar
sorry if it sounded if i was being mean. i thought i was just giving out alittle friendly advice. of course, after rereading my post, i could see how it could be misunderstood.
Old Jan 20, 2001 | 11:53 AM
Car: Death Mobile
Engine: 666 c.i.
On the issue of the "speed holes" drillled into the blade, it would screw up the vacuum of the engine. I am curious on how the VE tables would interpret this loss of vacuum, but I am unwilling to experiment on my car.
Probably the same effect as a vacuum leak...erratic idle, lean condition, etc.
Old Jan 20, 2001 | 05:41 PM
87Z-ya's Avatar
Part of the fun of public boards is that you can talk s%$t. Check out our website for street racers http://www.texasracingscene.com/
All we do is talk **** and everyone knows each other, its hilarious. Yea you might look stupid on a web board, but who cares if someone makes fun of you? Its not like 8th grade when you had a hard on and the teacher asked you to stand up is it? Thats humiliation. Have fun real life is to serious.
Old Jan 21, 2001 | 04:28 AM
88IROCs's Avatar
Actually, I find real life to be less serious. People can see by the glint in my eye whether I am at WOT on the BS or whether I am being serious(rare). Not to mention that using grammar/syntax, vocal inflection, twang and drawl all give clues to my demeanor.
Posting here means [trying] to communicate with people I have never met. This runs the risk of a newbie taking my opinion for gospel(scary) or an old-timer rebuffing/rebuking me for overlooking some apparently(I thought) insignificant detail. Tough crowd indeed, but it keeps ya honest
Glenn,
Good point on the stupid questions issue. "Stupid" questions prevent stupid mistakes. And the stupid mistakes are the ones that cost ya(hard won personal experience).
Old Jan 21, 2001 | 10:54 AM
Dan W's Avatar
Um, I may be going out on a limb here but the main fuel table is indexed by RPM and manifold pressure. TPS is used for enrichment mode and pump shot. It'll rev to the moon if you remove the throttle blades... I'm not about to try on my car to find out though
Old Jan 21, 2001 | 11:29 AM
85F-body's Avatar
i am in 8th grade and have a hard on though
jk
jhawkeye
May 25, 2022 06:33 PM
theshackle
Sep 17, 2020 08:26 AM
lakeffect2
Aug 23, 2015 08:44 AM
novaderrik
Aug 10, 2015 12:44 PM
3rdgenparts
Aug 8, 2015 07:09 PM
