TPI fuel rail fitting sizes???
Old Aug 9, 2007 | 03:21 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
does anyone know the stock TPI fuel rail fitting sizes.... i kno accel makes the fuel line fittings to connect to the stock rubber lines, wat im talking about is the lines out back/front of it for the hard lines that run under the plenum that connect the 2 rails together? gona see if i can make some new lines to fit the HSR!
any ideas? or pics of this done etc?
Old Aug 11, 2007 | 07:48 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
Re: TPI fuel rail fitting sizes???
I'm not 100% sure I uderstand what your asking....but do you mean something like this?
That modification was done by street and performance
I used a fuel rail jumper kit from Arizona TPI to connect my lines from the fuel rail to the frame line on my vette.
http://www.aztpi.com/product.php?pro...6&cat=0&page=1
Old Aug 15, 2007 | 01:11 AM
Car: 87 TA clone
yea but i was wondering how i could use those fuel rails on a holley stealth ram.... the 2 conecting lines that run between the fuel rails the one in the front and the rear with the fuel pressure regulator.... if those could be taken out and a new hard line bent in place? with the inner connecting rails taken out wat size fittings would i have to use and can it even be done?? it doesnt look like it can be.
i cant use the center lines bc the HSR is solid aluminum there. and 350$ for the fuel rails and a acceptable regualator arent really appealing.
wruiz
Aug 13, 2015 09:07 PM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
knight72
Aug 10, 2015 09:32 PM
92projectcamaro
Aug 6, 2015 01:20 PM
