This rubber hose ok for TPI?
Old Aug 10, 2007 | 09:52 AM
SS ninja's Avatar
Engine: 5.7 vortec crate w/TPI
Transmission: 2004r
http://store.summitracing.com/partde...5&autoview=sku
Does this seem like it would work for a TPI application? I was planning on using a short length of it by the fuel tank for flexability.
It's advertised as having a working pressure of 50 psi and a max pressure of 175 psi, but the actual wording states that it's meant to be used for carbureted vehicles. Also, it seems really cheap for what it is; I always thought that FI hose was pricey ($4-5/ft)
Old Aug 10, 2007 | 11:05 AM
Vader's Avatar
Re: This rubber hose ok for TPI?
FI hose is usually rated for 100 PSIG working pressure. Even AutoZone has it.
Old Aug 10, 2007 | 11:44 AM
SS ninja's Avatar
Transmission: 2004r
Cool, glad I asked before something bad happened!
Old Aug 10, 2007 | 02:13 PM
DZcode's Avatar
Car: 1969 Z28
Engine: 406 TPI
Transmission: Tremec TKO 600
Axle/Gears: 3.31
I'm not expert, but fuel injection hose (SAE J30R9) is more than just rated for high pressure. It's also less permeable than carburetor rated hose (SAE J30R7).
Just get real FI hose and sleep well at night.
Old Aug 10, 2007 | 02:58 PM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
you can get the real stuff at almost any parts store.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
