cant figure out where this went??help pics inside
Old Aug 10, 2007 | 11:57 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
aight well my dad took it off and cant remember how it went.i tired for a good 30min, thought it went along the coil bracket but the vacuum lines wont let it go.so any input or pics that one is install would be great..
88 camaro 350tpi
Old Aug 11, 2007 | 12:47 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Re: cant figure out where this went??help pics inside
I believe it's the EGR vacuum solenoid and it bolts onto the coil bracket.
Old Aug 11, 2007 | 01:50 AM
blackbird615's Avatar
Car: 1991 Trans-Am "Blackbird"
Engine: 305TPI LB9
Axle/Gears: Hmm
i can't help you with where it goes precisely, though i know one line feeds into the front, under the throttle body and the line is a very tight fit to it. see if you can feed it to the throttle body where its connected- where the fitting ends up might be in the general vicinity of where it is on the engine. all i remember is that it's to the back of the plenum, and to the left of the distributor. with the two vacuum hoses pointing straight up.
that is however, if memory serves me correct... it's been a long day.
Old Aug 11, 2007 | 02:36 AM
Synful's Avatar
what blackbird said is mostly correct
goes towards the passenger side of the distributor, the rubber fitting should have the hoses pointed up.....one hose goes to the bottom of the TB, other hose goes to the EGR valve
it attaches to the bracket that your coil attaches to
to make the fit easier and ease the strain on the hoses, you might just go buy new longer hoses, just make sure everything is attached and it'll be fine
Old Aug 11, 2007 | 07:57 AM
alpine247's Avatar
Car: 1988 IROC-Z
thanks..should be putting the engine down back in the car today..
Old Aug 11, 2007 | 09:44 AM
alpine247's Avatar
Car: 1988 IROC-Z
went out and tried to install it,still cant figure it out.i know i should have pull it off.so can somebody post a pic that would be great thanks
Old Aug 11, 2007 | 10:15 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I just had that part off my car yesterday as I was installing a new intake. That bolts inbetween the coil and the bracket off the intake, on the passenger side right next to the distributor. The tab just sits ontop of the bracket and then put the coil ontop of it, using the bolts to go through the coil, through that tab, and into the bracket... sort of sandwiched inbetween if that makes sense.
Besides the two vacuum lines, there is also a wire/plug-in that faces the firewall that needs to be connected.. the wire usually falls behind the distributor, don't forget to plug it in. If the vacuum lines are too short you'll need to re-route them to work, or as someone suggested, lengthen them.
Good luck.
Old Aug 11, 2007 | 05:50 PM
Wheel Spin's Avatar
Car: 89 Formula 350 (x 2)
Axle/Gears: BW 3.27
Yep, if the coil is installed, unbolt it, slide the bracket in question underneath the coil, re-mount the coil. You'll get used to this as you start adjusting the distributor for timing (access to dizzy hold-down).
Old Aug 11, 2007 | 10:21 PM
alpine247's Avatar
Car: 1988 IROC-Z
thanks,everything back in place like it should
1984HO
Mar 19, 2021 11:59 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
antares57
Aug 6, 2015 07:47 AM
