A.I.R Injection
Old Aug 12, 2007 | 01:49 AM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
A.I.R Injection
I am looking to upgrade to headers and I was wondering if removing the air injection setup and smog pump will throw my computer of or harm anything?
Old Aug 12, 2007 | 08:06 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: A.I.R Injection
No. Just the atmosphere.
You could get headers with the AIR ports if you decide to keep it.
Old Aug 12, 2007 | 01:27 PM
Car: '87 Iroc-Z
Re: A.I.R Injection
Thanks, so how do i remove it and also the smog equipment?
Old Aug 13, 2007 | 08:26 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: A.I.R Injection
Yank it out.
Follow the new belt routing https://www.thirdgen.org/serpentine
Old Aug 13, 2007 | 11:25 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: A.I.R Injection
lol yeah i took a sawsall to mine!
Mine ia an 87 so it was just cut the belt and un bolt everything.
Hardest bolt to get to is on the passanger side. It hlds the pipe that comes around from the drivers side.
Old Aug 13, 2007 | 12:38 PM
Car: '87 Iroc-Z
Re: A.I.R Injection
I have an 87 Iroc also. Can someone just point me in the right directions with detail please?
Old Aug 13, 2007 | 01:28 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Re: A.I.R Injection
Disconect the battery
1st thing to do is cut the belt to the pump (you should have a single belt just for that)
And start cutting things off to make it easy to take things off.
Like I said I used a sawsall to get rid of all thoes metal lines that go into the exhaust. Get rid of all the hoses up on top that are connected to the pump in any way.
If your getting new headers make sure you get them without the air tubes.
You can unbolt the pump and the bracket, cut the hoses and toss them in the trash.....no point in saving anything.
You can go under the car, You can remove your Y pipe. Remove your starter, & your o2 . Then start taking off your exhaust manafolds. Once thoes are out of your way you can finish taking off all the piping from the air pump. On the top of the block on the passanger side. One of the tubes is bolted down here. (it runs from the drivers side to the passanger side) And its a pain in the butt. There is also some ground wires here, so make sure you dont forget to put it back together less the tube bracket. The tranny dip stick tube might bolt on here also, I forget. Watch your oil dipstick tube when you pull the passanger side manifold out. Once everything is out, you can start in install your headers. Make sure you get some good gaskets and some nice header bolts.
Also make sure you tape up the electical connecton off the air pump.
Put your starter back in.
Install your Y pipe.
Dont forget the O2 sensor.
Reconnect the battery
I know I missed some things or some steps.
Ive done it 2 times so far, once on my car and once on my buddys 89 GTA.
PurelyPMD
May 5, 2016 04:57 PM
NZKnight
Oct 15, 2015 02:47 PM
racereese
Oct 10, 2015 09:39 PM
shanelique22
Sep 24, 2015 06:30 PM
