Edelbrock manifold question
Old Aug 13, 2007 | 10:01 AM
T-rick'srod's Avatar
Car: '88gta
Engine: 383 tpi
Axle/Gears: 3:23 australian 9 bolt posi
Hey Ya'll, last night I was mocking up my motor to check the oil pump drive shaft end play. I installed the head gaskets and aluminum heads - just snugged the heads - didn't torque 'em down. Next,I tried to install my Edelbrock HighFlow TPI base. Here's where my problem comes in. I could get
the bolts in one side only - on the other side the bolt holes were about .100"
off. The block was decked - leaving the pistons .010 in the hole. Should I
sort of slot the holes on the base and the gasket to make them fit or what ?
Has anyone had this problem ? Any and all help or suggestions will be greatly
appreciated !
Hey Moe, no wonder the water don't work -
these pipes is clogged up with wires.
Jerome Howard - 1936
Old Aug 13, 2007 | 06:29 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: Edelbrock manifold question
Just a thought but did you try the stock intake to see if that lined up? Probably wont since elebrock doesnt make crap but u never know.
Old Aug 13, 2007 | 08:23 PM
wanta427's Avatar
Car: 1991 Z-28
Engine: 350 L98 al head Stealth Ram
Axle/Gears: 3.42 LS1 brakes
use a flashlight and look in the ports to see how the runners match up . If they match slot the holes . Depending on which manifold gaskets you're using there might be thinner ones available.If it's no match on the heads you'll have to get the manifold milled . I had to slot the stock TPI manifold on my 350 but the stealth ram had room to spare
beastin91rs
Oct 9, 2015 07:38 AM
fasteddi
Sep 2, 2015 10:29 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
redmaroz
Aug 16, 2015 11:40 PM
