i need help where do these plugs go???
Old Aug 13, 2007 | 06:27 PM
pudgedawg007's Avatar
Car: 87 IROC
Engine: L98 5.7L TPI
Axle/Gears: 3:23
i just dropped my L98 in my iroc and of course it was awhile ago and things get misplaced or what not but i cannot figure out where this plug goes it is in the back near the dizzy it is NOT the plug that plugs into thevacmun thing under the coil it is plugged in already wire is i think orange with a black line and the other wire is black
also not quite sure where this one goes its up front near the plugs for the TB and the maf/map which ever it is
Old Aug 13, 2007 | 07:11 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: i need help where do these plugs go???
second one is for the alternator.
not sure on the first one
Old Aug 13, 2007 | 07:21 PM
Car: 87 IROC
Axle/Gears: 3:23
in my best carlos mencia "dee da dee" i knew that second one was something easy
Old Aug 13, 2007 | 08:06 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
The first one is probabley for that pig tail for the IAT sensor.
Old Aug 13, 2007 | 08:14 PM
Car: 87 IROC
Axle/Gears: 3:23
is that the one that plugs in on the bottom of the plenum?? if so i already have that hooked up
Old Aug 15, 2007 | 09:59 PM
billydonn's Avatar
Car: 66 c-10 stepside
Transmission: TKO 600
First plug looks like the "set intital timing" plug to me. Plugged in to dist. it allows ECM to adjust timing. You unplug it to set the static timing... then plug it in to drive. Should be a female mate to it back there off the dist.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
