Any experience with Brodix Track1 heads?
Old Jan 28, 2001 | 07:58 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I would like to build a 406 with a Mini ram and I was debating what cylinder heads to use. My local engine builder wants me to use Brodix Track1 cylinder heads, he believes they will work great with a 406 Mini ram. I am leary because the Brodix heads have very large 215 CC runner which might kill of all my low end power. Orginally I was planning to run some heads with a 190 CC intake runners like Trick flow or AFR.
The engine will be installed in a 1988 Firebird with a T-56 transmission with 3.70 gears. I do intend to drive this car every day, and the cruising rpm in 6th gear will be 1750 RPM. My max intended RPM for racing will be 6500 RPM.
Will the Brodix Track1 heads work well on a 406 Mini ram engine? Should I choose some other heads?
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.85
Best 60 FT street tires 1.930
Best MPH street tires 99.29
Old Jan 28, 2001 | 05:44 PM
burnoutrpm's Avatar
215 is kind of pushing it but you'll have tpi and you should make up for it. go with what he says, you cant beat brodix heads!!!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 heads,350 horse cam,bored.40 over, Edlebrock torker2 and a 600 edlebrock manual choke.
Future mods performer rpm air gap intake (polished) comp roller cam, and way better headsa 400 defintely in the works!
[This message has been edited by burnoutrpm (edited January 28, 2001).]
Old Jan 28, 2001 | 06:46 PM
FAST LiFE's Avatar
The Track 1's would be a very good choice for your motor. I was going to go with Track 1's for my motor now, but the deal I got for these Trick Flow 23 degrees was just too good to pass up. The guy's at Lingenfelter had suggested the Track 1's for a 406 Superram setup I built a couple years ago as well as Gromm Racing Heads in San Jose.
Since you're running the Miniram, you're obviously not worried about the heads not having the EGR passage.
We've got a 377 with the Track 1's and a Miniram that very streetable and runs 10's. Don't worry about the 215cc's being too much. With the cubic inches you're running, it's comparable to a 350 running with AFR 190's or 200cc Sportsman II's. You'll still have alot of bottom end torque, especially with the 406. Hope this helps.
N/A 406, TPIS Miniram, 58mm TB, 30lbs injectors, Custom Ground Elgin Cam, Ported TFS heads, SLP 1-3/4", & DFI computer.
11.70@117mph
Old Jan 28, 2001 | 08:33 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Thanks for the responses.
gta90
Sep 15, 2015 04:00 PM
Magman
Sep 12, 2015 10:43 PM
509 camaro fan
Sep 6, 2015 10:43 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
