L98 vs. LB9 TPI
Old Aug 14, 2007 | 08:08 AM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
L98 vs. LB9 TPI
Is there any difference? I am thinking of buying a L98 out of a C4 Vette. I would like to use my current TPI (since I have it polished) and sell the other TPI. If there is any difference, what is it? Thanks!
Old Aug 14, 2007 | 08:36 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: L98 vs. LB9 TPI
You should be fine.
Old Aug 14, 2007 | 08:44 AM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
Re: L98 vs. LB9 TPI
only thing you need to keep from the L98 are the injectors.
Old Aug 14, 2007 | 11:06 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Re: L98 vs. LB9 TPI
and you'll need a custom chip to run the bigger injectors. go to www.lsracingchips.com for a good chip for a good price.
You'll need to run your F-body fuel rail since the corvette one feeds from the opposite side.
You also cant run the corvette oil pan and oil pump pickup because it will hit your Y pipe.
You'll also have to route exhaust gas from the passenger side manifold/header into the back of the intake base if you plan on running EGR with the stock corvette intake base. If you use your f-body intake base you cant use EGR at all since vette heads dont have an exhaust crossover.
I can't think of anything else right now........
Old Aug 14, 2007 | 12:52 PM
Herkavi's Avatar
Re: L98 vs. LB9 TPI
Different user, similar question for clarification. So ifI were to get a stock L98 block, I could use all of my LB9 components? Throttle body, runners, exhaust manifold, etc? Of course I would need the L98 chip, and bigger injectors as stated above. What size injectors does the L98 use, are they 24lb or are they still smaller than that? Thanks in advance.
Old Aug 14, 2007 | 11:04 PM
Abubaca's Avatar
Re: L98 vs. LB9 TPI
L98 is/has 22 pound injectors.
Old Aug 15, 2007 | 01:55 PM
Rick Routzahn's Avatar
Re: L98 vs. LB9 TPI
would 25 lb injectors work also?
Old Aug 15, 2007 | 02:00 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: L98 vs. LB9 TPI
With chip tuning.
Old Aug 16, 2007 | 09:08 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: L98 vs. LB9 TPI
25, 19, 21 pounders will all work without tuning just not very well. If you keep the 305 ecm keep your stock injectors and turn up the fuel pressure; I however would program a new prom chip for the engine with whatever injectors you buy.
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
mrestrictrplate
Aug 27, 2015 09:37 AM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
