Which Heads To upgrade to on 91 Z28
Old Aug 17, 2007 | 12:34 AM
texasgomer's Avatar
Car: 91' Chevy Z28 (white)
Engine: 355 TPI
I'm wanting to upgrade my heads on my 355 TPI from the stock head without putting a different cam. I need some feedback about Vortec's, Dart.s etc... What is the best set-up to get around 300-340hp out of my car ??? Thanks for any help with this.
Old Aug 17, 2007 | 03:13 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: Which Heads To upgrade to on 91 Z28
Port the stockers and spend the saved cash on a Stealth Ram and a cam.
Old Aug 17, 2007 | 04:20 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
You'll need a cam for those numbers.
Old Aug 21, 2007 | 05:32 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Junk those stock heads and get a set of Trick Flows.
Old Aug 21, 2007 | 09:08 PM
Or throw on a set of used Vortecs, small cam, and Stealth Ram for about the same price.
Old Aug 22, 2007 | 12:29 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Or you can buy my L98 heads hahaha thread is in the fs section
Old Aug 22, 2007 | 01:29 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Fast-burn heads and a SDPC vortec TPI intake. The heads allready come with upgraded springs, they are aluminum, and the 62 cc chambers will bump compression up slightly.
Frozer!!!
Jan 19, 2024 04:55 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
86White_T/A305
Aug 17, 2015 12:16 AM
