will this add a significant increase in power
Old Jan 22, 2001 | 04:49 PM
85F-body's Avatar
i was going to get either some high flo runners , 58 mm tb and a comp cam OR new aluminum heads. they both end up costing about the same and i wanted to know which ones would make more hp or a large difference in horse power cause i am only looking to spend about 1.5k on this car
Old Jan 22, 2001 | 06:46 PM
mirage2991's Avatar
if you still have the 305 in there, I'd say heads. Big power gain are in the heads, and try to save a bit more for a cam. 85 are non-roller so it should be like 100 bucks for cam. 305's don't need 58mm and or aftermarket intake stuff, unless you are supercharged. While you are at it, clean up the intake (port match it) and you should be all set!!
later
85 Z28, 355, edelbrock base, SLP runners (old style) 58mmTB, ported plenum, stock cam, fuel reg, TES headers, flowmaster, 3.73's, shift kit, MSD 6a, 305 hypertech chip (YUUUCK!) best prior intake mods: 14.6 @ 94, 2.02 60' temp: 78deg, 80% moist, on radials.
69SS, black, 3,73's, TH400, 402 BB, roller everything (solid 246@50 622 lift)+stud-guirdle, 67 Vette heads ported and o-ringed, about 10:1 cr KB pistons, should be done this summer, goals: 500hp and lots of fun
Old Jan 22, 2001 | 07:29 PM
85F-body's Avatar
i am going to have my plenum ported by my friends dad and ya that is what i was thinking that a 58 would be a bit big for my car
Old Jan 24, 2001 | 12:55 AM
burnoutrpm's Avatar
i say go with the cam! if its a hyd roller then you'll get great increase in tourqe and lots of hp! remember: the cam is the brain of any engine!! any engine!! it decides the valve events, how it idles, what it sounds like and how she runs! everything! then later put a tb , heads (qutie a investment!) but well worth it! remember not to go over a 200cc intake runner on street heads. then do the plenum and runners!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 heads,350 horse cam,bored.40 over, Edlebrock torker2 and a 600 edlebrock manual choke.
Future mods performer rpm air gap intake (polished) and , comp roller cam, and way better headsa 400 defintely in the works!
[This message has been edited by burnoutrpm (edited January 23, 2001).]
Old Jan 24, 2001 | 02:57 AM
Dan87IROC-Z's Avatar
Mirage is right about everything. Heads are where the most power is trapped on lots of engines, good heads will ALWAYS help your car out lots. A 58mm TB is ment more for 350 cid or larger engines using mini ram or super ram induction. High flow intake parts usually only work well on 350s and above when lots of other mods have been done. Plenum and base porting do lots for any cid engine too. Make sure you have a high flow exhaust, good ignition and a good cam, and your 305 will hang with most 350s!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Gutted Catalytic Converter, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, Ported TPI Plenum and Base, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 2, 2001 | 12:20 AM
tastedapain's Avatar
CHECK OUT MY AD FOR EDELBROCK LARGETUBE RUNNER COMPLETE SET UP....ALL POWER NUMBERS ARE THERE!!!FEEL FREE TO ASK ANY QUESTIONS....HAPPY RACING!!
Old Feb 4, 2001 | 10:32 AM
85F-body's Avatar
well where and what is it
customblackbird
Aug 15, 2021 10:16 PM
midge54
Dec 27, 2019 04:14 PM
evilstuie
Feb 28, 2016 03:33 PM
sailtexas186548
Aug 24, 2015 10:11 PM
g.l.mos
Aug 22, 2015 12:02 AM
