Will 1.6:1 RR's negatively affect stock '89 L98?
Old Aug 20, 2007 | 03:02 AM
Penix's Avatar
Car: 1979 Camaro Sport Coupe
Engine: 350 LM1 with 083 2.02/1.60 heads
Transmission: TH350, soon to be 2004R
Axle/Gears: 2.41, soon to be 3.42
The engine and ECM are stock, and being that it's an '89 the engine has a MAF sensor. Would this be okay? I ask because my friend just bought a new set of heads with guide plates and will sell me his 1.6:1 Comp Cams Pro Magnum Self-Aligning Roller Rockers, and for cheap! Only $100, and they've only got 5000 miles on them.
So, will this work? Oh, and will these fit under my stock valve covers?
And yes, while I'm at it I'm gonna replace the seals and springs aswell.
Thanks in advance guys!
Joel
Old Aug 20, 2007 | 11:47 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Will 1.6:1 RR's negatively affect stock '89 L98?
Should be just fine. Be sure to check the clearances when you are all done. Not all heads etc are created equal.
lt500r55
Sep 1, 2021 01:30 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
