091 vs 093 heads
Old Aug 21, 2007 | 06:38 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
091 vs 093 heads
I have an '87 5.7 TPI with tired 091 heads on it. I can get a set of fresh 093 heads. They have the same size valves, but the combustion chambers are a different design. Good idea or not?
Old Aug 22, 2007 | 12:33 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: 091 vs 093 heads
Do you mean 083 heads? I haven't heard of 093 before. 083's are pretty weak standard 350 tpi heads. Heavy, not much room for improvement, not worth the $$$. If you're looking for stock replacements, they should work fine.
Also you said you have 091 heads? Can you provide the entire casting number? THose don't sound familiar either.
Will
Old Aug 22, 2007 | 08:12 AM
jv9999's Avatar
Engine: 5.7L/350
Will
Sorry, I meant 191 and 193. It has tired 4102191s on it now, what I can get a good deal on is 14102193s.
-jim
Old Aug 22, 2007 | 08:46 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
hmmm whats a good deal though?
cause i have a set of 113s,ready to bolt on,fresh 3 angle valve job for a goood deal!
Old Aug 22, 2007 | 08:48 AM
jv9999's Avatar
Engine: 5.7L/350
$200 with new SS valves, 3 angle valve job, and milled .010.
Old Aug 22, 2007 | 09:05 AM
Car: '88 Trans Am
Engine: 5.7L TPI
not too bad. PM sent
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
