Questions about VSS!!
Old Feb 7, 2001 | 09:23 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Ok, I swapped my transmission and a couple weeks later the speedo quit working and I haven't fixed it yet!! "Sometimes" I get a SES light but it's just a VSS code! I read that the VSS reads the speedo (electic) and lets the computer know how fast you're going so that the computer can "limit" your speed! Since my speedo isn't working the computer isn't receiving a signal from the VSS and that's why the SES light trips!! Now....the REAL question here is this!! What else does the VSS do??? I've heard of people having cold start idle problems due to a bad VSS????? Is this true.... or is the sensor just simply there for the computer to limit the speed???
1986 Trans AM
305 TPI
4 Wheel Discs
9 bolt Borg Warner Rear
Completely Stock
Soon to upgrade to a 383 stroker w/TPI, Headman Shorty Headers, AFR 190cc Heads, ported intake, comp cam, TPIS air foil, Adjustable Fuel Pressure Regulator (probably Holley), 24 lb/hr SVO injectors, and some sort of aftermarket ignition (undecided)!
Current project: Keeping my car running until I get the money for the above mentioned project! :-)
Old Feb 7, 2001 | 11:27 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
The vss does have an effect on the operation of the engine. The computer uses the vss to help control some of the engine functions. You should fix your vss.
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.85
Best 60 FT street tires 1.930
Best MPH street tires 99.29
Old Feb 8, 2001 | 07:30 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yeah, it does more than just limit the speed. Definatly get it fixed.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors, Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
