Any Ideas?
Old Aug 23, 2007 | 08:05 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Any Ideas?
My car has been spit sputtering at idle lately so i decided to give it some gas hoping maybe it would clear out something. Well as im in 2nd and the rpms are rising all of a sudden the car seems to just stall out.
It shuts down engine wise and i started hitting the gas pedal to give it gas hpoing i culd get it back. No luck. It sputtered a bit and then just stalled out. I still had all electrics. I then tried to restart the car after letting it sit for 5 minutes. It kicked over for a second then nothing.
I towed it home then sprayed some starter fluid in it and tried to start it. It did the same thing. Any ideas. I'm guessing its the fuel pump. I know i should check it with a fuel pressure gauge and w/e. but I thought i would post this.
Old Aug 24, 2007 | 10:48 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Any Ideas?
Sounds like the fuel pump is failing. I would check that first. If that is ok, then check the module in the distributor.
Hope this helps!
Old Aug 24, 2007 | 11:20 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: Any Ideas?
now the distibutor module is on there. its like that little sensor thing?
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
