BackFiring!!
Old Feb 11, 2001 | 01:12 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
BackFiring!!
It first started about 2 months ago. When ever I would get on it every once and a while It would back fire. now if Im reving it up just alittle it backfires alot. im thinking clogged fuel injectors??. I dont really have time to send them and get rebuilt but someplaces around have a "3 step injector cleaner" i guess they hook somthing to the fuel rail and use pressure to clean them. Is this advisable or is it not the fuel injectors?
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Feb 11, 2001 | 01:33 PM
The ODB's Avatar
Nope not injectors.
Remove valve covers and visually check the condition of your valvesprings looking for a broken spring.
Next get a leakdown test performed on every cylinder looking for a bad leak.
This will eliminate a possible major problem first off and give you peace of mind knowing if it's a cracked or bent valve, or broken valvespring.
If that's all good then do your normal troubleshooting for the possible little problems.
good luck
ODB
Old Feb 11, 2001 | 03:54 PM
F22Raptor's Avatar
ODB, even though you turned against me, I have to admitt that you do know more than just basics when it comes to cars. You are right about the springs. Had that problem; turned out Jeg's had put the wrong numbers on the catalogue, so I bought springs that were binding and breaking, making the car backfire and obviously run like $hit. Called Crower and fixed the problem. Jeg's never refunded my money though.
Rick
Old Feb 11, 2001 | 04:03 PM
The ODB's Avatar
Rick,
Are wanting to call a truce?
fair enough for me.
Bo
Old Feb 11, 2001 | 04:24 PM
F22Raptor's Avatar
I don't know man. After you betrayed me? hum, maybe.....I'm pretty hard headed you know!
yeah why not....but you better watch it or i'll have to "crack" your head...hehe!
Old Feb 11, 2001 | 10:28 PM
Car: 1991 Z28
are you sure?? I dont think the valve spring is broke. my car still runs pretty good.
Old Feb 12, 2001 | 01:00 AM
burnoutrpm's Avatar
ok it could be the springs but it could also be the igition being a tooth off on the distributor placement. or a fualty ignition item somewhere. or the timing is just relly way off?! if the springs are seeing coil bind then its the springs without a doubt!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) Edlebrock torker2 and a 600 edlebrock manual choke (1405)
Future mods performer rpm air gap intake (polished) comp roller cam, and way better headsa 400 defintely in the works!
Old Feb 12, 2001 | 02:59 AM
F22Raptor's Avatar
Check the springs. It won't cost you anything and will definately give peace of mind. I was able to go to work before I found out I had a broken spring. Also, check your distributor gear; the teeth might be really worn out and mess your timing (happened to me). You might wanna check the spark plug wires, they will definately mess your car up if just one is cut, burnt or else, although I don't know if that would make the car backfire. Just check everything you can and fix accordingly. that's the best and cheapest way.
Rick
Old Feb 12, 2001 | 10:28 AM
bdiroc's Avatar
Car: 1989 camaro
Engine: 355 tpi
Transmission: 700r
Axle/Gears: 3.50
i was just wondering what your fuel pressure is set at? when i set my pressure at 50 psi the motor would backfire if i keep in high rpm for very long .dropped fuel pressure to 46 and the backfiring went away hope this helps .
Old Feb 12, 2001 | 06:38 PM
The ODB's Avatar
Chris,
Are you backfiring through the intake or exhaust?
ODB
tyeo098
Nov 30, 2015 06:27 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
