CAM Questions?!?!?!?
Old Feb 13, 2001 | 10:21 PM
Doogie92Z28's Avatar
I have a 91 Z28. I have flowmaster exhaust, slp headers, wires, plugs, TPI, and a chip. I want a pretty aggressive cam. The ones with that more rough idle. How big can i go?
Old Feb 14, 2001 | 01:57 AM
Dan87IROC-Z's Avatar
Is it a 305 or a 350? We all really need to know before we can help in selecting a cam for it.
If its a 350 as my car is, I have to champion the LT4 Hot Cam from GMPP. Although I am currently in the process of installing it, I know its a cam that will work well for my engine as well as yours.
If your car has the 305 motor, the only semi-first hand knowledge I have is with the smaller of the 2 SLP cams. Although pricey it worked wonders on my friends 89 IROC 305.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
