...how many cc's are the stock cast iron L98 heads...
Old Feb 15, 2001 | 02:00 PM
jimbo's Avatar
Car: 1991 Formula Firehawk (Clone)
Engine: 350 with Firehawk Package
...on the 1991-1992 f-body 350, and what was the stock compression ratio? Also, isn't there a link on this board somewhere to the 3rd gen Camaro database...
...could swear I saw one here not too long ago...must be going blind...
TIA
Old Feb 15, 2001 | 02:17 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
64cc
Old Feb 15, 2001 | 02:28 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
What is the compression ratio for a L98 engine with those 64cc heads on it?
Reason I ask is I was told the ZZ4 short block with the 64cc heads would be 9.5:1 requiring premium gas
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, highly modded
95 Trans Am Conv.- LT1
Old Feb 15, 2001 | 02:45 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
87-89 L98's are 9.3:1. 90-92 L98's are 9.7:1. I'm not 100% on this. You should be using premium fuel anyway. Or you can get by with 89 if you dont race and you arent getting any knock. Leave the timing in the stock setting or make it 4º if you're going to run less than 92 octane.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 15, 2001 | 03:28 PM
R.O.B.'s Avatar
I know that using the ZZ4 short block with Vette heads, 58cc, gives 10:1 compression. Using the Fastburn heads, 62cc, gives 9.6:1 compression. So with this being 1cc per point, I would guess that 64cc heads would give you 9.4:1 using the ZZ4 short block.
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
junkcltr
Aug 2, 2019 11:12 PM
Genopsyde
Oct 7, 2015 08:35 PM
InfinityShade
Aug 22, 2015 08:00 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
