Still running like ****
Old Aug 30, 2007 | 07:52 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Compression. 150 psi on all 8
( using 3 crank method)
Timing 6 degrees
TPS .55
IAC adjusted
Fuel pressure Aprox 43 Psi
new plugs, Wires are good and in correct firing order.
Mass air Circuit tested, Working perfectly, and at the time the MAF was outputting the correct numbers. ( As i recall 800 ~ Millivolts @ 900 Rpm )
Runs like this MAF plugged in or not
No Vacuum leaks, Or not one big enough to cause it to run like it is...
Distributor Has no awkward Play, newer Cap and Rotor
Valves adjusted While running 1/2 turn past 0 lash, No clattering
* Recent Work*
( still ran like *** before the work, i was hoping this would cure it)
Ecm
Timing chain( Old one was sloppy as hell)
zz4 Cam
24 pound fuel injectors
new roller lifters
BBK AFPR
And all associated gaskets
thats all i can think of at the time.
Thanks!
Old Aug 30, 2007 | 09:52 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: Still running like ****
is it throwing any codes?
Old Aug 30, 2007 | 10:28 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
last time i checked them ( before cam work etc)
It would only give a VSS 24 code, on decel.. Because i dont have it hooked up
Ill have to check them tomorow once again
Old Aug 31, 2007 | 02:17 AM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Did you program for the chip and cam? Mixture is going to be off with those 24lb injectors. You will need to programing in the chip.
Old Aug 31, 2007 | 06:32 AM
fire350tpi's Avatar
Axle/Gears: 3.23's
24 lb injectors are 9 percent of from 22 pnd, the computer can compensate up to 16 percent
besides, it ran like this before all the work
Old Aug 31, 2007 | 10:44 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Ignition module, pickup coil in dist., coil, or engine grounding are all big crap makers if all else is good. Could also be a bad ECU (the 165 isn't the most robust ECU out there).
Check spark with a timing light to see if it's firing all the time on all the cylinders. Check spark with a spare plug on each cylinder to see if it's nice looking or weak.
Old Aug 31, 2007 | 05:41 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
Redngold86z
ECM has been replaced
I looked with a timing light and detected a small skip on a few cylinders
im going to double check all fuses today and possibly tighten some grounds
Old Sep 2, 2007 | 01:51 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
I checked spark on a few wires with a spare plug orange, weak spark
pulled the distributor and am in the process of putting in a pick up coil and module now, /crosses fingers
Old Sep 3, 2007 | 01:10 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
Distributor had alot of play in it, and it needs a bronze gear but
I threw it back in, i have a white/blue strong spark now
Runs much better now
Maybe i just need a new distributor
Old Sep 4, 2007 | 05:13 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
well that motor is gone, I noticed the oil pressure die out when it warmed up and i drained the oil and it is grey and full of metal
whatever caused it, idc it just sucks
rebuild time!
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
