Will a 84 carb fuel tank work in a 86 tpi car as a replacement?
Old Feb 18, 2001 | 07:48 PM
njdaewoo's Avatar
From: Newark,NJ> Where street racing on I 78 RULES!
I just removed the gas tank from my 86 tpi trans am and I noticed that tank is all rusted through on top. Fuel leaks out if tank is full. I have a extra 84 fuel tank out of an 305 carbed motor camaro. Do u think it will work? Do the tpi fuel tanks have diferent baffles inside to control the fuel slosh better?
thanx for any info!
njdaewoo
Ps: Its cold as hell laying on that ground outside my house in the winter time changing fuel tanks!!!!!!! IIIMMMMMMM'''' COLDDDDDDDD>>>
406 sb
dart 200 heads(out the box)
144 B&M blower
373 gears
Edl headers
3in cat back Flowmaster exh.
270 comp cams
12.50s @ 115mph
on street tires
60ft time 2.30
www.njdaewoo@excite.com
New Project car
86TPI trans Am
All stock for now
Old Feb 18, 2001 | 10:33 PM
The ODB's Avatar
It will fit and work no problem. I would run an inline pump with it though. You may also have to modify one of the tanks vent tubes to use as a return line. The return lines should be run low into the tank to prevent a lot of splashing that can create static... so I'm told (never seen static in a fuel tank)
good luck
ODB
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
beachrodder
Aug 25, 2015 08:05 AM
marcusaw
Aug 10, 2015 08:13 AM
MENINBLK
Aug 5, 2015 11:58 PM
