rough idel tpi 350
Old Sep 3, 2007 | 08:49 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
rough idel tpi 350
First off i have a 1987 350tpi formula. the car has a rough idel. It starts up fine but the RPMs drop when it first starts and i have to hit the gas alittle to keep it alive. when it finally alive and running the car has a choppy rough idel shaking the whole car. I checked alot of thinks ignition system MAF new spark plugs replace my EGR solenoid. what could it be? I need help. can it be the egr itself I tryed looking for vacuum leaks but have not found anything.
Old Sep 3, 2007 | 09:25 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: rough idel tpi 350
check your idle air control motor. if its stumbling on idle at low rpms it could be a diry IAC motor. it sits under your throttle body. take it off and clean it and clean the throttle body bores/etc.
mine did this earlier this year and i took a look at my IAC and it was dirty as can be. Idles fine now
Old Jul 9, 2008 | 12:31 PM
88I_R_O_C_ZTPI's Avatar
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
i know this is a long shot but did you ever find the culprit ?
jbd1969
Aug 17, 2015 07:06 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
