For those of you running 383's
Although I'm a TBI'er i know that there are more of you running 383's in here than in the TBI room. It not fuel related anyway... I was wondering what depth pan you are using on your thirdgen's. It seems that the only pan i can use is the 8 1/4" deep pan. (i have the moroso 20180). This pan sits very low on my car leaving only about 5-6" between the pan and that hard thing called the ground. I called Summit and Jeg's and both of them said that the stock pans have the wider rails where you bolt it down and the one i have has a narrow rail which is why it leaves room for the extra rotaion (since you also have to notch the block). BTW.. im using a pre-80 block .. but i think thats irrelevant - (Just In Case).
What pans are you using and how much clearance to you have?
Thanks for your help
Im using a regular production pan on mine with no problems.
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.
"Just remember children, no man can beat you once youv'e found the cliterous." 'chef'
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
Stock GM pan here too, no problems, even with ARP main studs and clipped/modified windage tray.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
KevinP92Z
