Gulping air into the Throttlebody?
Car: 1992 rs
Axle/Gears: ones that turn
Car: 1992 rs
Re: Gulping air into the Throttlebody?
Ive changed the TPS it fixed the issue for abou ta week then back to the same old thing. I have recently switched back to the TPS chasing another demon......
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
That air filter isn't helping the cause either. The factory calibration relies a little bit on the restriction of the air filter housing to reduce the surge of air on a throttle snap.
Does it feel bad when driving it?
You can fix it with prom tuning though, if all your sensors are working.
Car: 1992 rs
The TPS voltage is ok .55 V. no flat spots that i can tell. No Vacuume leaks, fuel pressure is good, timing is 12* . Its been doing this since I put the TPI in it. About the only sensor that is not new is the IAT, MAP,CTS, and fan switch. EVERYTHING else is new. Dizzy, all ignition components, injectors are new/used no problems with fuel, new ecu/prom burned by fuel injection specialist, im kinda leaning towards the MAP.
On another note, I had another problem with hesitation intermittently right after an injector swap. When I went to ohm the injectors last thursday night and the hesitation has completely cleared up??? Not sure what to make of that, but oh well.
