need advise from experienced TPI'ers
Old Sep 6, 2007 | 07:32 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Hi gang,
I am still having fuel delivery problems.
I just installed a new fuel pressure regulator and problem still exists.
When I turn the ignition on I cant get more than 35 PSI fuel pressure no matter how I adjust the regulator.
When I fire the engine the car starts and runs for about 30 seconds and fuel pressure drops to zero. Pump is running and pulling proper amps even though pressure dropped off.
Car is a new build and has no street time. engine did run and fuel pressure was good while running in shop over the last few months.
I finally got everything worked out and was ready to street test then this started.
please help
thx
jeff
Old Sep 6, 2007 | 08:12 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: need advise from experienced TPI'ers
Since I didnt see a before thread, and only this one.
I assume injectors are new, or atleast tested.
FPR new.
Pump atleast runs.
I'm going to guess a bad pump, or the rubber hose that goes between the pump and the "holder" popped.
Old Sep 6, 2007 | 08:20 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
How old is the pump? fuel filter?
Old Sep 6, 2007 | 08:24 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Have you checked your fuel filter?
Old Sep 6, 2007 | 08:39 PM
DZcode's Avatar
Car: 1969 Z28
Engine: 406 TPI
Transmission: Tremec TKO 600
Axle/Gears: 3.31
I'm assuming you retrofit TPI to an 84 T/A and you already placed a high pressure TPI pump in the fuel tank with the required special SAE30R10 gasoline resistant/submersible rubber hose from the pump to the fuel line.
Pinch/block the fuel return line. If your pressure increases, I'd suspect a bad fuel pressure regulator. If pressure does not increase, then I'd suspect the fuel pump is bad or the hose that connects from the pump to the fuel line inside the tank has come off or is broken. That rubber hose submersed in the tank must be SAE30R10. Regular fuel injection hose, SAE30R9 and regular fuel hose SAE30R7, will “melt” and burst under pressure when submersed in gasoline.
Old Sep 6, 2007 | 08:54 PM
jjlabinski's Avatar
Engine: shinny 350
thanks guys..every single component is brand new and I did use fuel injection hose at the pump.
My last suspicion was the pump hose and everyone that replied suspects the same thing.
bitch is I just filled the tank and took the car off the lift. Now that it dont run it is going to be fun to push it back on the lift to remove the tank.
even more of a bitch is this will be the third time I removed the tank.
First time was for the complete resto. second time was to install an intank pump instead of the in line pump I was supplied when I bought my fuel injection system.
thanks again
jeff
Old Sep 9, 2007 | 04:17 PM
jjlabinski's Avatar
Engine: shinny 350
my fuel line was R9...I never heard of R10.
where do I get?
lot of re-work for such a small item.
thx
jeff
Old Sep 9, 2007 | 06:41 PM
DZcode's Avatar
Car: 1969 Z28
Engine: 406 TPI
Axle/Gears: 3.31
Jeff,
I purchased a walbro fuel pump install kit from
http://www.autoperformanceengineering.com/
I already had the walbro fuel pump, but needed the install kit with the connector, the sock filter and the J30R10 fuel hose.
The site states they don't sell the accessories by itself, but when I e-mailed they said to ignore that statement. They will sell you an install kit ($10.00). I'm not sure if they will sell you just a 6 inch section of hose ($1.50).
VR,
Alan
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
perZ
Aug 21, 2015 05:51 PM
stalkier
Aug 21, 2015 01:54 AM
Sanjay
Aug 12, 2015 03:41 PM
