no start 350 tpi
Old Sep 7, 2007 | 08:24 AM
8996chevy's Avatar
Car: 89 IROC
Engine: 355
Transmission: 5 sp., Alum Driveshaft
Axle/Gears: 3.73 Posi
no start 350 tpi
need help, while driving car just died. had it towed home and started checking.
NO SPARK. 45 lbs fuel pressure. tried different spark control module, ignition coil, pickup coil, tps sensor, wiring, couldn't find anything. I'm assuming the parts i tried were good, but who knows. any suggestions? how much oil pressure is needed while cranking to allow ecm to give spark? thanks
Old Sep 7, 2007 | 09:48 AM
DZcode's Avatar
Car: 1969 Z28
Engine: 406 TPI
Transmission: Tremec TKO 600
Axle/Gears: 3.31
Re: no start 350 tpi
The oil pressure sensor allows the fuel pump to continue running. That sensor's input is not used to control spark.
My only experience with a no spark condition was VATs (mistakenly left on during a TPI retrofit) and a bad ignition coil.
Old Sep 7, 2007 | 07:30 PM
8996chevy's Avatar
Car: 89 IROC
Engine: 355
found out what the problem was. distributor gear was worn down on one spot. gear wasn't meshing with cam, so it stopped turning, hense, no spark. cleaned out oil pan with magnet, changed oil and filter. rebuilt distributor, sprayed gunk down hole and let it drain out oil pan. fired right up. no more problem. thanks
theshackle
Mar 5, 2017 06:37 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
