Need some mods for a 85 305tpi Trans am
Old Feb 22, 2001 | 02:09 PM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
the only thing i've done so for is a k&n air filter and flowmaster exaust plus bosch platinum spark plugs. I want it to run in mid 13's.
Old Feb 22, 2001 | 03:00 PM
Dan87IROC-Z's Avatar
You can start with all the free mods. These free mods increase your power and make a noticeable seat of the pants (SOTP) differnece. The free mods consit of porting your intake plenum and base (if you have a dremel), removing the screens on your MAF senson, by-passing the throttle body coolant, making an adjustable fuel pressure regulator, and if you don't hvae to pass emissions, you can gut your catalytic converter, remover your smog pump and all AIR and other emissions stuff, and you can remove your A/C if you don't use it.
The next thing to do, if you haven't done it already is to do what I like to call a performance tune up. You already have good plugs, get a good MSD or Accel cap and rotor kit, put synthetic oil in the engine, tranny and rear end, adjust your TPS and IAC and make sure your engine is in prime running condition.
Then, the first real mod I suggest to people is a high flow cat-back, which you already have with your flowmaster. My suggestion now would be to get a set of headers. I know a lot of people, especilly with the 305 who really like the 1 5/8" TES headers from Edelbrock. After that, you can improve your drivetrain with a new set of gears (3.42 w/ auto, 3.73 w/ 5 speed), and if you have an automatic, you can get a higher speed stall converter. You can also look into cams and heads to improve your engine. Since its a 305, spending lots of money on high flow intake parts usually isn't worth the money from what I have heard.
The mods I listed above you can learn more about in detail in the tech section of this site and also at other sites on the web. Vader, a moderator here at thirdgen, has an article he can email you on making your own AFPR.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 25, 2001 | 11:17 PM
rdog30's Avatar
Car: 85&95 Trans am
I already have 4:11 gears. The article by vader sounds good.send it my way.
Old Feb 26, 2001 | 11:15 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
You can also swap out that crappy "870" computer. Go with an '86-'89 "165" ECM. That way you don't have to worry about that $961 MAF Burnoff Module when it goes south on you.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
fbirdroller
Sep 2, 2015 10:27 PM
Hello, Michael
Aug 20, 2015 03:19 PM
PestilenceIV
Aug 20, 2015 02:33 AM
jbd1969
Aug 17, 2015 07:06 PM
matthew911
Aug 12, 2015 09:38 AM
