350 TPI is going in my jeep!
Old Sep 9, 2007 | 11:07 PM
roguecoxnet's Avatar
Already have it broke down. I'm getting a rebuild kit and I can't decide on the camshaft. PLEASE HELP! I've searched but theres nothing on this for an off-road vehicle. I'm wanting LOW-End Torque and HP and because its a Jeep YJ I don't need to go over 75 MPH. If someone can take 1 minute of time and give some much needed advice it would help out so much.
1987 350 TPI out of an IROC (Stock)
Camshaft: ?
Valves: ?
Pistons: ?
Lifters: ?
Old Sep 10, 2007 | 12:08 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Re: 350 TPI is going in my jeep!
A crane 2032 wouldn't be a bad choice. It's something like 214 .452 220 .465 on a 112LSA and probably 4 degrees advanced built in. Only about 8 degrees more intake duration than stock, and a little narrower LSA, and a little more lift. I would probably use it with 1.6 rockers, too. A little more than stock stall converter would probably make it an excellent low speed driver. Only mild chip tuning would be necessary, if at all (if kept MAF).
I put a Lt4-hotcammed 350 and 195AFR heads into my dad's 79 4x4 truck, and a 2000rpm stall converter, and it hauls **** for a truck. Not soggy at all. The hot cam is a little bigger than the 2032 even (218 intake).
Old Sep 10, 2007 | 12:06 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Comp Cams makes camshafts specifically for the 4x4 applications. I would look into one of those.
Old Sep 10, 2007 | 05:41 PM
Could you give me a link for the right cam so i can look into the numbers more. I'm new to the numbers and don't have alot of experience with intake/exhaust ect....
Old Sep 11, 2007 | 12:54 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
I'm going to pull my TPI outta my 88 Vette and put it in my hooked up XJ myself one day soon. Then slap a LSxxx into my vette. I think my jeep would love that upgrade.
good luck
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
