cross fire to tpi
Old Sep 10, 2007 | 12:29 PM
cyko83's Avatar
Car: 83 trans am
Engine: 5.7 V8
Transmission: 700R
cross fire to tpi
i need some help on a convertion on my 83 trans am. i'm trying to make my car in to a tpi. i already have the intake and comp but need the harness for it.
the problem is , my car has two harness the leftside controls the the starting of the car and i geuss the other side DID control the fuel and other thing i think?? i'm not to sure about it because when i bot the car it was turned into a 4 barrow carb.
last year i bot a mass air flow harness and tried to connect it to the comp(it connected ok) but there are two other connections from the car that had to be connected but had no where to go. ( that is my problem)
Old Sep 10, 2007 | 12:33 PM
sikZ28's Avatar
Car: 86 Trans Am
Re: cross fire to tpi
I can't really help you much other than telling you to stay away from an 85 TPI harness.
Old Sep 14, 2007 | 11:36 AM
cyko83's Avatar
Car: 83 trans am
Engine: 5.7 V8
Transmission: 700R
ttt
1992rs/ss
Jan 31, 2025 05:10 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
