How do you clean your TPI equipment??
Old Feb 26, 2001 | 10:12 PM
CamaroX84's Avatar
I am rebuilding a TPI motor, and I will be painting the block and the heads gloss black. My question is, what do you guys do to clean all of the aluminum stuff on your engine. I don't want to polish it, just make it look new. Any help would be much appreciated. Thanks.
1984 Camaro Sport Coupe - 73K Miles
5.0 Carbed LG4
COMPLETELY stock except for a K&N Air Filter
F41 Suspension Package
700R4 Tranny
3.08 Rear End
New Paint
Best 1/4 Mile Run:
16.760 @ 80.74 MPH
Coming Soon:
350 TPI
Complete 3" Exhaust System
Aluminum Drive Shaft
3.27 Disc Brake Posi Rear
Old Feb 27, 2001 | 02:37 AM
93ND500's Avatar
Have them glass bead blasted. Just make sure that you tape off any machined surfaces. After that you can clear-coat them if you feel the need.
1993 C1500 Indy 500 Edition
1992 TA TPI setup
Stock motor, new one being built now.
www.geocities.com/wsleigh
Old Feb 27, 2001 | 07:46 AM
Steve89GTA's Avatar
Have it powder coated!...you can even powder coat it Aluminum Colour if you like. It will never chip and will look good virtually for ever. Fuel and chip resistant! I do powder coating up here in Toronto.
For a TPI unit (plenum and runners) I charge $100CDN to blast, prep and coat.
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Autometer Vac+Oil Temp
Old Feb 28, 2001 | 12:45 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Bead blasting is nice. I had an edelbrock 3701; had it bead blasted before I sold it; came out very nice.
I'm having the tpi runners, base, 'stat housing, and plenum all b.blasted this week; install starting next sunday. I plan on hitting them w/ some high temp clear (I want a stock look)
jmd
L69 / T5
Vintageracer
Jan 10, 2020 05:33 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
