Looking for a Cold Air Intake system for a 87 Firebird Formula
Old Sep 11, 2007 | 11:49 PM
Formula1987's Avatar
Apparently something is different from the 88+ firebirds from the 87 firebirds when it comes to Air intake systems because all Cold air systems i see for the third gens only fit 88-92 models. If anyone has a link to 87 Cold air kits or regular intake kits it would help me alot. Thanks
Old Sep 12, 2007 | 09:32 PM
87_gta's Avatar
Car: 87 GTA / 87 IROC-Z
Engine: 350 TPI / 350 TPI
Transmission: 700R4 / 700R4
Axle/Gears: Stock
Re: Looking for a Cold Air Intake system for a 87 Firebird Formula
go to the slp web site there is one there to fit 85-87 setups, or u can just make ur own. i did that works for me
Old Aug 28, 2008 | 09:01 PM
Steveh4263's Avatar
Car: 1987 Pontiac Trans AM GTA
Engine: 5.7 LTR
Transmission: Automatic
What did you all have to do to make a cold air intake work on your 87 GTA? I know you have to connect it to the MAF but what else did you do or needed to do?
Old Aug 31, 2008 | 12:46 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
First off, unless you are willing to relocate your fuel vapor canister, don't even go with cold air induction. It will need to be removed, along with your stock air filter box and the tray they sit on. The SLP cold air box is simply a big plastic box that sits down into that same location, and it connects to the inside of the fender. From that point you will need the stock intake flexible connectors from a 88-89 model, you can reuse your same MAF. When I bought my 87 it had this set-up, I don't have any of the stock '87 intake parts that the car originally came with. The last owner of my car took out the vapor canister and did not relocate it, now I have fume problems under the hood. If you'll look at the stock '87 air filter canister you'll notice the air hose connects into the side of it, the 88-89's connect to the top, that's the biggest difference.
Now for the chrome types you see on ebay, you can leave the tray and the vapor canister, but remove the stock air filter canister only. You will still need the "L" shaped flexible piece from a 88-89 though. This is not technically a "cold air" system, but it's an easier option (and looks good).
1992 Trans Am
May 10, 2023 07:19 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
