A TPI Combo that Works!!
Old Feb 28, 2001 | 09:29 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Just got done installing my new equipment. i got a Edelbrock Base (ported it myself) AS&M LTR's , Extensively Ported Plenum, MSD 22lbs Injectors to replace old leaky 22's and a BBK 52mm TB and man this car hauls a$$ now. I pins me in the seat good. I recommend this combo to everyone.
89 Formula 350
Old Feb 28, 2001 | 10:01 PM
The ODB's Avatar
sounds good!
you must have done something right.
89 formula 350's run great just stock. Did yours come with aluminum heads and dual cats?
ODB
Old Feb 28, 2001 | 10:10 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
F- Bodys never came with AL heads just the vette L98's did. Naw I dont have duel cats eather. Before the intake swap my best was 14.2@ 98 hoping for 13's now
Old Mar 2, 2001 | 11:35 AM
Yelofvr's Avatar
Mkos:
In my opinion you are approaching the optimum street motor. I have studied many torque curves of many SBC combos and my current favorite is the following: 52mm TB, ported plenum, AZS&M large tube runners, Accel base, ported L98 aluminum heads, or eqivalent. and a 211/219 Lingenfelter roller cam. This motor has a wonderful torque profile for a street car. Torque comes on strong at 2000 rpm due to the mild cam and early intake valve closing point, and is still good at 5200rpm. I am finishing a very similar combo, except I went with the 383ci. My motor is in my CJ-7 Jeep with 35" tires so I need the torque.
Dave Zelinka
Old Mar 2, 2001 | 11:49 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Mkos,
I had a similar combo before I did heads/cam MiniRam. With TPIS BigMouth base, ported plenum, 52mm TB, AS&M LTRs, and SLP headers (and other little stuff like exhaust, pullies, chip, suspension) I was able to run 13.6's@102mph. VERY strong combo.
My biggest complaint about this setup is that the car could not be launched from a stop. WAY TOO MUCH torque. I had all of that power but couldn't use it because it is impossible to plant that much torque on the street. However - this combo was deadly from a roll ...
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Mar 2, 2001 | 03:35 PM
The ODB's Avatar
I only asked because a friend of mine ordered his 89 Formula 350 with the aluminum head engine back in 89. It ran very good.
Old Mar 2, 2001 | 05:12 PM
vortech305's Avatar
we almost have the same combo
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
Sanjay
Aug 12, 2015 03:41 PM
