Number one cylinder not firing!!
Old Mar 4, 2001 | 05:06 PM
SCOTT91Z's Avatar
i am not getting the number one cylinder to fire. i checked the plug wire its good. spark plug is good injector is spraying fine. what could it be? any suggestions?
Old Mar 4, 2001 | 05:18 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You have spark though the plug? Pull the plug, turn it over (with plug in the wire) and see if it sparks between the electrode.
You sure you have the plug wires routed correctly?
If so, then could be an issue with the valves, maybe a burnt one...a compression check might then be in order.
Old Mar 4, 2001 | 05:19 PM
98_1LE's Avatar
Well it's either spark, fuel or compression. If you are sure that it's getting a good spark under cylinder pressure and that the injector is spraying, then I would do a compression check.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
masonta
Sep 1, 2015 06:40 PM
