TPIS vs. Arizona speed and marine.
Old Sep 15, 2007 | 01:23 AM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
Hey guys I need your opinion. I am going to upgrade my stock tpi intake and runners with aftermarket parts. I'm going to keep the long tube runner set up. I like the tourque and I drive on the street 99% of the time so I don't need most of my power to come on in the upper rpm range.
I was going to get tpis big mouth intake and their runners. Then I heard that the arizona intake runners flow more air. Is this true?
Old Sep 15, 2007 | 01:55 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: TPIS vs. Arizona speed and marine.
AS&M runners are really nice pieces. Pricey, but they are very well made. I don't know too much about the TPIS runners, but the big mouth base seems to be pretty popular. I would check the port sizes and see how they match up to the AS&M runners. I know plenty of guys running the AS&M runners and they love them.
Will
Old Sep 15, 2007 | 01:58 AM
yaj15's Avatar
Car: 1988 IROC-Z
What bases work well with the arizona intake runners?
Old Sep 15, 2007 | 02:41 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Any aftermarket lower intake will fit the AS&M LTR's.
It wont mount on a FIRST, unless you contact someone
Edelbrock/Accel pieces are the common option, choices
are limited when it comes to TPI intakes.. hopefully BBK
will have another option for us TPI guys.
The AS&M's will bolt up to a stock intake as well..
Anybody know if the LTR's are still on a backorder?
Old Sep 15, 2007 | 12:56 PM
yaj15's Avatar
Car: 1988 IROC-Z
Thanks for the info guys. I know the selection is limited. I like the long tube set up and the way it looks stock so that limts me to a few companies.
Do you guys have any idea why tpis's parts cost a lot more than other companies like accel or edlebrock? From what I have read the power gains from the intake and runners are about the same.
Old Sep 15, 2007 | 01:47 PM
norcalz28's Avatar
My guess would be because they are a smaller outfit, and are not as well known as accel or edelbrock, who can keep their prices SLIGHTLY lower because of volume. However, it seems that edelbrock is the manufacturer of accel's base now anyway. So regardless of what you chose, you are getting the same thing. The edelbrock runners are also basically the old accel runners with the addition of those fins and logos. I think Edelbrock bought the rights to accels superior setup, and now has the sole manufacturing rights. I could be wrong, but it makes sense.
The main difference between the AS&M runners and others like ed or slp is that they are aluminum tubes vs. ed/slp one piece cast aluminum. This makes them lighter, but more prone to damage much like the stock pieces would dent and ding. I personally think the AS&M runners are about as high quality as they come. The machine work looks excellent, which can't be said for other mass production companies.
I would get some as&m runners, and a superram base, port your plenum extensively to match the rest, and it should flow nicely, and extend the rpm range a little.
Will
Old Sep 16, 2007 | 12:35 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
TPIS long tube runners are the exact same casting as AS&M long tube runners, but with a higher price tag. AS&M semi-siamese runners would be the better choice, but they are severly hard to find and always on back order. Accel long tube runners would be my next choice.
Edelbrock is the only one still making aftermarket intake manifolds for the stock bolt pattern, and they are the least expensive. Edelbrock also makes the Vortec intake for the Chevy Vortec heads, but Scoggin Dickey sells it cheaper.
Old Sep 16, 2007 | 01:56 AM
yaj15's Avatar
Car: 1988 IROC-Z
Thanks for the input guys. I've decided to go for some arizona intake runners and an edlebrock base. This should match up well with the rest of the plans for the motor that I have. Now that the intake is done I just need to pick a set of heads and a camshaft to match but that will be a while down the road. At least now the intake will be set up right.
Old Sep 17, 2007 | 05:12 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
I went with the Edelbrock base and SLP runners. Cost was a factor. and of course, performance. I ported the Edelbrock TPI manifold base at the transition from the CNC machining to the as-cast surface. I haven't been disapointed. as you may have gathered, porting of YOUR factory upper plenum is very rewarding, most importantly, the ridge right behind the TB.
Old Sep 17, 2007 | 10:33 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I am using the AS&M runners with the TPIS intake. It's a very good combination.
Just a heads-up... when you order from AS&M, tell them whether you need the 9th injector port or not. Mine came with it by default and I had to send it back to them to plug (which they did for free).
Hope this helps.
Old Sep 17, 2007 | 01:35 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
I don't know this for a fact but... Edelbrock makes the TPIS intake and they are the same. The Arizina speed and the TPIS runners are the same. Regardless, they are all very comparable. FWIW.
Old Oct 3, 2007 | 09:44 AM
91-RS-B4C-fake?'s Avatar
Car: 1991 Camaro B4C
Engine: L98 350 cid (5.7L) TPI v8
Transmission: 700 R4 auto trans
Axle/Gears: 10 bolt w/girdle & 3.42 MotiveGears
If you have not already bought your
TPI intake manifold, you might want
to check out the GP (Group Purchase)
section.
I'm trying to round up buyers & negotiate
a price of $350 + shipping for the
TPIS Big Mouth intake manifold through
John Robie's robiecustoms.com
The more buyers we can get the better
chance of actually getting the $350
purchase price.
Check it out...
And add your post if your seriously interested.
Keith5
Aug 27, 2015 04:37 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
IBrockZ
Aug 20, 2015 12:20 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
