Code 42. Someone help this poor guy
Old Mar 3, 2001 | 10:56 AM
theformula's Avatar
Someone please tell me what the hell could cause this. I have to be in jersey in an hour and it just happened 2 min ago!!!!! I have all new plugs , wires, cap, rotor
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5275rpm limit),Holley 9mm wires,Ac delco R43ts plugs,fastchip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Mar 3, 2001 | 11:19 AM
JETHROIROC's Avatar
Code 42: Electronic Spark Timing - Could be a poor electrical connection or a short, a defective ignition module or bad ECM. My vote is for the ignition module going out. Are you having any bad driveability symptoms? The ignition module is very easy to replace, it's held down by two screws under the cap.
Old Mar 3, 2001 | 11:22 AM
theformula's Avatar
Well, whenever I get past 3k the rpms float around.
I thought the ignition module was under the distributor in the housing?
Old Mar 3, 2001 | 11:31 AM
JETHROIROC's Avatar
On mine I can get to it if I pull the cap and rotor ('90 350 TPI). The module is where the wire harness connects to the back of the distributor. Just make sure if you put in a new one to liberally apply that heat sink compound that comes with it or the new one will fry quickly.
Old Mar 4, 2001 | 04:33 PM
robert1's Avatar
Yeah, check the ECM. Get one from NAPA, they have a year warranty, where most others have 90 days
Old Mar 5, 2001 | 09:12 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Okay, first, you didn't mentioned if you had any "drivability" problems. The tach deal can be just the tach acting up. Mine did that a while back and then replaced it. A code 42 will stick if you only disconneted the EST bypass wire to check timing without shorting the AB terms at the ALDL.
If a code 42 is all you're getting, your ECM is probably still good. Look into the module and pickup coil in that distributor and wiring therabouts.
IROC-Zone
The Camaro Shrine
'88 Camaro IROC-Z 350 TPI
'98 Grand Prix GTP 3.8L SC
"Yea, though I walk through the valley of rice,
I shall fear no Turbo; for Torque art with me."
- Cullan Hooley
Old Mar 5, 2001 | 09:15 PM
theformula's Avatar
I'm getting bad driveability problems. Stalls out on me. Sometimes when I start it , it surges. What could it be? I also got code 51 (Prom Error)..
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
apie2546
Aug 10, 2015 05:43 PM
