SR, AFR 190, LPE 219 cam car dies while stopped in gear
Old Mar 6, 2001 | 12:26 AM
TheFormula350's Avatar
Just got off the phone w/ the shop that installed my new SR, AFR 190s, LPE 219 cam and they said the car is running well except it dies while stopped in gear (ie stopped at a red light in D or in R). The shop said that a higher stall converter (stock right now) will be needed to fix the problem. Is this the only solution or could something else be wrong/adjusted? Thanks for any help...
Matt
87 Firebird Formula 350
Old Mar 6, 2001 | 02:18 AM
The ODB's Avatar
check the IAC.
have the idle settings changed on your chip.
check if tranny fluid is low.
Old Mar 6, 2001 | 11:37 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
With your new mods, especially the SR(SuperRam), the minimum air must be reset along with the TPS voltage and static base timing. There is a specific method for this, it is located in the tech articles, check them out.
Also, you should have a custom chip made for your engine and I'm NOT talking about an Hypertech chip.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, my custom chip, Lay Ind. ram air kit, SS Brakes 1LE upgrade 12" rotors dual piston calipers, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter, next mod: 4.10 rear gears
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
Wade787b
Sep 29, 2015 01:15 PM
camaro71633
Sep 1, 2015 10:24 AM
hokis
Aug 9, 2015 03:57 PM
killer777
Aug 8, 2015 02:47 PM
