TPI won't start... could the FPR be bad?
Old Mar 7, 2001 | 05:19 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Well, I got the pump in and it still stutters and hesitates. Now, it won't even crank at the key. We had a hot-wired push button starter under the hood and it will crank the motor, but it will not start? It has spark and injectors, MAP, TPS, pump, wires, plugs, and cap/rotor are all GOOD! Can the fuel pressure regulator be bad? We are almost sure its a fuel problem... possibly the ECM? We thought the problem maybe got worse after putting more fuel pressure against the FPR with the new Holley pump. Thanks for any help!!
'91 GTA:
www.fbody.com/members/91WS6GTA
Old Mar 7, 2001 | 10:20 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Maybe time to buy a fuel pressure gauge and check it out...better that throwing $$ at parts, plus extra tools are cool
Old Mar 8, 2001 | 12:08 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Pressure is fine, but my dad found out the ECM fuse was blown. Bad ECM?
'91 GTA:
Old Mar 8, 2001 | 05:21 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
Probably not a bad ECM, but a short somewhere... check all the wiring that you can see, I know, it's tedious, I've had to do it before. Chasing a short is one of the biggest PITAs there are. Do you have a shop manual? They can be a HUGE help in situations like this.
One other thing, you might want to check your ESC module, and make sure you haven't knocked off the wires leading to your distributor cap, I did that once while putting my runners back on and couldn't figure out for the life of me why the car wouldn't start. Cost me $200 just to have some idiot at the dealer find that wire and put it back on. Why so much? He said because of my aftermarket (Accel) coil he had to charge extra... what a crock.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
89GTAOz
May 16, 2020 09:31 AM
86IROC112
Aug 17, 2015 02:00 PM
wayshegoes
Aug 17, 2015 12:00 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
