Formula for matching cam with heads?
Im curious if there is a standard formula for matching the heads with the duration of the cam using intake cc or flow numbers of the heads, or possibly projected HP peak? If it helps, the heads Im getting have 170cc intake runners and I estimate my HP peak at somewhere around 4800RPM. Anyone? Thanks!
'83 Firebird 2.8
'89 Firebird Formula 350
2nd owner, red/grey, t-tops, dual cats, and a 3.27:1 rear
K&N, TB bypass, No MAF screens, CAI, full Accel ignition
'83 Firebird 2.8
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You usually go with flow numbers. If your heads flow their best at .500" lift, you pick a cam with .500" lift or so. Duration will depend on what RPM you want. At 4800 RPMs, you want a cam with 208-212 intake duration. See the cam tech article on this website for more info.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
ambainb
Apr 25, 2016 09:21 PM
